R50/53 How many and what type of rubber exhaust hangers needed for oem?
Old May 2, 2016 | 09:30 PM
patsum's Avatar
patsum
Hey everyone, I have an 06 R53 with an aftermarket IE catback exhaust. I don't like it so I bought a lightly used OEM catback exhaust with the two metal straps
I know that I need the rubber hangers in addition to it being welded back on. I see roughly 4 places I need the rubber hangers as well as a metal bar that stick out closer to the middle front of the car that I don't know what that needs.
Can anyone tell me what hangers I need and how many?
I found these
http://www.autohausaz.com/pn/MZ-18201176013
But I also see I may need ones with screws that go through them?
Please help me out, how many and what kind do I need?
This is what I have, the whole system plus metal brackets on each side. Nothing else.
Old May 3, 2016 | 10:05 AM
MINIAC's Avatar
MINIAC
Have the "one ball" exhaust mod done before installing it ...
Old May 3, 2016 | 10:58 AM
patsum's Avatar
patsum
No. The exhaust system that I have has absolutely zero rust on it whatsoever and I would prefer not to mutilate it until 5-10 years down the road when half of it rusts out and the need arises, until then I would like to enjoy a quiet full factory system.
I still need to know how many and what type of hangers I need for this?
Old May 3, 2016 | 02:03 PM
David.R53's Avatar
David.R53
Put your vin into realoem.com and you can pull up the diagram. Each "ball" has two rubber things from what I recall.
Old May 3, 2016 | 02:18 PM
Looks like you have the pre 1/2004 exhaust with the hangers all bent forward, you have a 1/2004+ MINI so the insides hangers will need bend inward if you want to go back to stock.
https://www.ecstuning.com/Mini-2004-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Exhaust/OE/2
The pre 1/2004 both hangers pint in the same direction.
The post 1/2004+ has the one hanger that points to the side.
Old May 3, 2016 | 04:51 PM
David.R53's Avatar
David.R53
The metal plate mid-car has two rubber mounts also. But those are different. Look at the picture here for the stock 2006 R53
http://www.realoem.com/bmw/enUS/show...diagId=18_0489
Old May 6, 2016 | 12:35 PM
JeffM's Avatar
JeffM
If you don't want to bend the hangers (or can't), you can also buy just the top half of the clamps with the hangers attached. They are interchangeable between the earlier and later versions. Lower half is the same.
Old May 16, 2016 | 09:25 PM
patsum's Avatar
patsum
Hey guys I'm posting pictures of my actual exhaust unit and the actual metal hangers as I don't know if mine are pre 2004 or not. Can any of our sponsors link me to where I can buy all the rubber hangers needed for this OEM exhaust install? and how many and of what type?
Attached Thumbnails How many and what type of rubber exhaust hangers needed for oem?-file-may-17-12-11-38-am.jpeg   How many and what type of rubber exhaust hangers needed for oem?-file-may-17-12-10-57-am.jpeg
Old May 17, 2016 | 04:56 AM
Posted above , looks like you have the post 1/2004+
Scrodes
Mar 31, 2016 07:18 PM
Rchitct
Mar 28, 2016 05:51 PM
aaroncapafons
Mar 24, 2016 10:15 PM
Morganinaboat
Mar 24, 2016 11:36 AM
Lopez421
Mar 15, 2016 09:30 AM
