R50/53 No "Trifecta", but still a relentless TPMS light - have error codes
Old Apr 23, 2016 | 09:08 PM
twoj's's Avatar
twoj's
Small Edit: See post #2 for a list of different BMW fault codes for ABS systems. Does anyone know which system an early R50 has?
Hi guys and gals. This is a topic that seems to be pretty well covered and I assure you I have done a bunch of searching through threads trying to find my answer to no avail.
I recently acquired my R50 and it came with the tire pressure light lit up. I have gone through the reset procedure many times and it does nothing. I do know that the switch has power as it is illuminated when the lights are turned on. I have also ensured that I have correct tire pressures.
I bought the Creator C310 OBDII scanner tool (I have an airbag light on as well) and pulled the codes. The result I got are codes 5E19 CAN data fault from DME/DDE (DSC lamp on as long as error is present) and 5E5C Initialize run flat indicator (see owner's handbook).
I don't believe my car has DSC, so I don't get a DSC lamp. I have searched a ton for info on the 5E19 code and most of the time it seems to be related to a faulty ABS sensor -- which would make sense with the tire pressure light. I am a bit confused though as people with the same code say that it can point towards a faulty steering angle sensor, which my car shouldn't have since it does not have DSC.
However, I would expect the ABS light to be lit if that were the case -- and I think every thread I've read where someone had a faulty ABS sensor, they also had the "trifecta" of DSC/Tire pressure/ABS lights. When I turn my key, the ABS light does come on with all of the other dash lights, so I know that it is working.
Can anyone make any sense of this? In the morning, I will see if I can find the ABS module under the hood and test resistance across the connectors to see if I can find one of the sensors that is out of spec.
Questions I have:
  • Have you seen something like this before?
  • Does anyone have the correct resistance values for the ABS sensors handy? I need to get myself a Bentley manual still.
  • Does anyone have a good source for a list of codes and their meanings? The only lists I have seen have all of the codes starting with a P or a Q -- I think those are the true OBDII codes (tire pressure not being a required OBD system). In a thread I read that the numbers in my codes may have meanings (like the 5 and 19 in 5E19 may tell me what sensor might be bad). I haven't found solid info on this. Is this listed in the Bentley manual?
Lastly, I have an unrelated question that I don't think needs another thread: I pulled my airbag code and got 05 Side Airbag, Front Left.
Would the side airbag be the one in the seat? I have read that the connectors under the seat are a weak point, so I will take a look at those. And I just want to confirm... left side is the Driver's side, correct? There is conflicting information on that on the internet (surprise!).
If you've read this far, thank you. And thanks for any help you can provide.
- Jordan
Old Apr 23, 2016 | 09:31 PM
twoj's's Avatar
twoj's
Searching for BMW ABS Code Meanings. I don't know which system my car has, but they all seem to have something in common...the number 5 seems to point towards the right rear wheel speed sensor (5).
I am still curious what the E and 19 might mean. At this point I just need to check the sensors, but it kind of bothers me not knowing exactly what the code(s) mean.
BMW ABS fault code list. BMW ABS fault codes and their meanings. Definitions list
BMW ABS fault codes.
Bosch 2E ABS
4 Rear left Wheel Speed Sensor (WSS)
5 Rear right Wheel Speed Sensor (WSS)
6 Front right Wheel Speed Sensor (WSS)
7 Front left Wheel Speed Sensor (WSS)
8 Rear Left Solenoid Valve
10 Front Right Solenoid Valve
11 Front Left Solenoid Valve
14 Solenoid valve relay
15 Hydraulic pump motor
21 Electronic Control Module (ECM) fault
24 Wheel Speed Sensor (WSS)
25 Brake Light Switch
ABS 1
1 ABS Hydraulic Unit
2 TPS
3 Ignition Timing Error
4 Rear Left Speed Sensor or ABS Inlet Valve
5 Rear Right Speed Sensor or ABS Inlet Valve
6 Front Right Speed Sensor or ABS Inlet Valve
7 Front Left Speed Sensor or ABS Inlet Valve
8 Rear Left ABS Valve
9 Rear Right ABS Valve
10 Front Right ABS Valve
11 Front Left ABS Valve
12 EGS Intervention
13 Idle Speed RPM Increasing
14 Valve Relay Fault
15 ABS Delivery Pump Fault
16 Throttle Valve Reduction
17 Front Left Wheel Sensor
18 Front Left Wheel Sensor
19 Accumulator -Pressure Limit
20 Front Left Wheel Sensor or EGS-Intervention Error
21 Front Left Wheel Sensor or ABS/ASC ECU Fault
22 Speed Sensor Signal
23 Equipment ERROR (Automatic/Manual)
24 Incorrect Pulse Generator
27 Idle Speed Signal
30 Left Rear Wheel Speed Sensor Cable
31 Right Rear Wheel Speed Sensor Cable
32 Right Front Wheel Speed Sensor Cable
33 Left Front (E38/E39) or Right (E46) Wheel Speed Sensor Cable
34 Front Right Wheel Sensor or ASC Switch Over Valve
35 Brake Fluid Level Signal
36 Front Right Wheel Sensor or Ignition Signal Error
37 Front Right Wheel Sensor or ABS/ASC Control Unit -Internal Error
38 Gas Valve Adjustment Error
39 Servo Motor - Electrical Error
40 Gas Valve - Potentiometer Error
41 Steering Angle Sensor Error
47 Outlet Valve - Rear Left
48 Outlet Valve - Rear Right
49 Wheel Sensor - Rear Left or Outlet Valve - Front Right
50 Wheel Sensor - Rear Left or Outlet Valve - Front Left
51 Inlet Valve - Rear Left
52 Wheel Sensor - Rear Left or Inlet Valve - Rear Right
53 Wheel Sensor - Rear Left or Inlet Valve - Front Right
54 Inlet Valve - Front Left
55 ASC Shutoff Valve
56 CAN ERROR (Short Circuit)
57 Throttle Valve Signal from DME
58 CAN ERROR (Open Circuit)
59 ASC Shutoff Valve
60 Signal Fault - Pin 30
61 Central Wheel-Blocking
62 Max Anti Blocking Adjustment Time
63 Processor Fault ECU
64 Continuous Control due to Undefined Signal Interference
65 Wheel Sensor - Rear Right or Feedback Signal
66 Wheel Sensor - Rear Right or Wheel Speed Sensor Power Supply
67 CAN ERROR
68 Wheel Sensor - Rear Right
69 Wheel Sensor - Rear Right
70 Error 70
75 ASC Indication Lamp
81 Inlet Valve Front Left
82 Inlet Valve Front Right
83 Inlet Valve Rear Left
84 Inlet Valve Rear Right
85 Outlet Valve Front Left
86 Outlet Valve Front Right
87 Outlet Valve Rear Left
88 Outlet Valve Rear Right
89 Power Supply Low
90 TimeOut - Passive Switching
91 CAN ERROR
92 Pressure Sensor Pre Charge Pump
94 RPM Sensor (Test)
95 Activation
96 Actuator Test
97 ASC Intake Valve / Steering Angle Sensor
98 Separate Valve
99 Electro Magnetic Switch Over Valve
100 Electro Magnetic Switch Over Valve
103 Brake Light Switch
104 Steering Angle Sensor
105 Brake Light Switch
106 Lateral Acceleration Sensor
107 RPM sensor (Gradient)
113 ABS /ASC Feed Back Pump
115 ABS/ASC Control Unit - Internal Error
118 Electromagnetic or Mechanical Interference -Wheel Speed Signals
120 Power Supply too High (> 18V)
129 ABS/ASC Main Relay Circuit
130 Power Supply - Solenoid Valves
131 Wrong Current - Solenoid Valves
133 Power Supply - too High
145 CAN chip in the ABS/ASC control unit
146 CAN ERROR
147 CAN ERROR - Engine Intervention
148 CAN ERROR - Engine speed (RPM)
149 CAN ERROR - DME/DDE connection
150 CAN ERROR - EGS
151 Coding Error
152 DSC Button
161 RPM Sensor
162 RPM Signal
163 Lateral Acceleration Sensor
164 Lateral Acceleration Sensor
165 Pressure Sensor 1
166 Pressure Sensor 2
167 Pressure Sensors
168 Pressure Sensors Power Supply
177 Pre Charge Pump
178 Pre Charge Pump
180 Steering Angle Sensor -Signal 1
181 Steering Angle Sensor -Identification
182 Steering Angle Sensor -CAN
183 Steering Angle Sensor -Internal
184 Steering Angle Sensor -Offset
ABS 2
2 EML Interface Fault
3 DME Interface Fault
4 Sensor Fault Rear Left
5 Sensor Fault Rear Right
6 Sensor Fault Front Right
7 Sensor Fault Front Left
8 ABS Valve Fault Rear Left
9 ABS Valve Fault Rear Right
10 ABS Valve Fault Front Right
11 ABS Valve Fault Front Left
12 Solenoid Valve Fault Rear Left
13 Solenoid Valve Fault
14 ABS Valve Relay Fault
15 Rear Feed Pump Fault
16 ASC+T Storage Valve Fault
17 Wheel Sensor / Inlet Valve Front Left
18 Wheel Sensor / Outlet Valve Front Left
20 Wheel Sensor / Inlet Valve Front Right
24 Wheel Sensor / Outlet Valve Front Right
33 Wheel Sensor / Inlet Valve Rear Left
34 Wheel Sensor / Outlet Valve Rear Left
36 Inlet Valve Rear Right
37 Front Right Wheel Speed Sensor
40 Rear Output Valve
49 Power Supply Solenoids
50 Throttle Valve Mechanical Fault
56 ASC Separator Valve Fault
65 ASC Computer Fault
66 DME RPM signal Fault
68 Control Unit Defect
72 Internal Fault
81 Speed Sensor Front Left Connection
82 Speed Sensor Front Right Connection
84 Speed Sensor Rear Left Connection
88 Speed Sensor Rear Right Connection
97 Speed Signal Front Left
98 Speed Signal Front Right
100 Speed Signal Rear Left
104 Speed Signal Rear Right
113 Speed Information Front Left
114 Speed Information Front Right
116 Speed Information Rear Left
120 Speed Information Rear Right
129 DME Connection
130 TPS
132 Brake Pedal Travel Sensor
133 Valve Power Supply too High
136 Brake Hydraulics -Quality
145 Hydro Pump Failure
146 Coding Faulty
148 Motor Temperature over CAN bus
152 Brake Pedal Travel Sensor -Hydraulics
161 Outlet Valve Front Left or Front Left Wheel Sensor
162 Outlet Valve Front Right or Front Right Wheel Sensor
164 Rear Left Output Valve or Rear Left Wheel Sensor
168 Rear Right Output Valve or Rear Right Wheel Sensor
177 Valve Power Failure
184 CAN ERROR
193 DME Ignition Signal
255 Accumulator Fault
ABS 3
5D90 Left Front Wheel Speed Sensor : Accident Recognition
5D91 Left Front Wheel Speed Sensor : Extrapolation
5D92 Left Front Wheel Speed Sensor : Periodical Control
5D93 Left Front Wheel Speed Sensor : Accident Recognition
5D94 Left Front Wheel Speed Sensor : Long Term Control
5DA0 Right Front Wheel Speed Sensor : Accident Recognition
5DA1 Right Front Wheel Speed Sensor : Extrapolation
5DA2 Right Front Wheel Speed Sensor : Periodical Control
5DA3 Right Front Wheel Speed Sensor : Accident Recognition
5DA4 Right Front Wheel Speed Sensor : Long Term Control
5DB0 Left Rear Wheel Speed Sensor : Accident Recognition
5DB1 Left Rear Wheel Speed Sensor : Extrapolation
5DB2 Left Rear Wheel Speed Sensor : Periodical Control
5DB3 Left Rear Wheel Speed Sensor : Accident Recognition
5DB4 Left Rear Wheel Speed Sensor : Long Term Control
5DC0 Right Rear Wheel Speed Sensor : Accident Recognition
5DC1 Right Rear Wheel Speed Sensor : Extrapolation
5DC2 Right Rear Wheel Speed Sensor : Periodical Control
5DC3 Right Rear Wheel Speed Sensor : Accident Recognition
5DC4 Right Rear Wheel Speed Sensor : Long Term Control
5DF0 Pump Motor
5DF2 Internal Error, Valve/ECU Hardware Error, ROM/RAM Check
5DF4 Power Supply too Low
5DF5 Control Unit Internal Error
5DF7 Power Supply too High
5E00 Tyre Test Active
5E01 Tyre Test Timeout
5E02 Tyre Test Gyration Sensor Justification Error
5E03 Tyre Test Gyration Sensor Error
5E04 Tyre Test Lateral Acceleration Sensor Error
5E05 Tyre test Lateral Acceleration Sensor Error and Gyration Sensor
5E06 Tyre Test Gyration Sensor Fault
5E07 Tyre Test Lateral Acceleration Sensor Error and Gyration Sensor Fault
5E08 Tyre Test Steering Angle Sensor Error
5E11 Internal Error CAN-Controller
5E14 CAN Timeout DME/DDE
5E15 CAN Timeout EGS
5E16 CAN Timeout Instrument Cluster
5E18 CAN DME/DDE Message
5E19 CAN DME/DDE Torque Reduction Not Possible
5E1A CAN DME/DDE Signal Error
5E1E CAN Timeout LWS
5E1F Steering Angle Sensor - not Initialised
5E20 Pressure Sensor 1
5E21 Pressure Sensor 2
5E24 Pressure Sensor 1/2 not Plausible
5E26 Sensor Power Supply
5E2F Temperature Sensor
5E30 Lateral Acceleration Sensor
5E32 Lateral Acceleration Signal not Plausible
5E38 Wheel Speed Sensor
5E3C Wheel Speed not Plausible
5E40 Lateral Acceleration Signal not Plausible, Offset
5E43 Lateral Acceleration Internal Error
5E4E DSC Sensor Offset Check
5E4F Long Time Regulation DSC
5E59 Coding Error
5E5B Switch Pressed Longer than 10s or Faulty
5E5D Brake Fluid Level Switch
5E5E Brake Light Switch
BMW ABS Teves MK 60
5D8C Dynamic Stability Control (DSC) sensor- CAN Timeout
5D8E DSC sensor incorrect
5D8F Dynamic Stability Control (DSC) sensor. Internal fault
5D90 Front left wheel speed sensor
5D91 Front left wheel speed sensor
5D92 Front left wheel speed sensor. Pulse gear faulty
5D93 Front left wheel speed sensor
5D94 Front left wheel speed sensor
5D95 Front left wheel speed sensor. Double frequency
5D96 Dynamic Stability Control (DSC) sensor. CAN Bus Off
5D97 Dynamic Stability Control (DSC) sensor. Voltage supply
5D99 Dynamic Stability Control (DSC) sensor. CAN controller: CAN fault CAN bus OFF
5DAO Front right wheel speed sensor
5DA1 Front right wheel speed sensor
5DA2 Front right wheel speed sensor. Pulse gear faulty
5DA3 Front right wheel speed sensor
5DA4 Front right wheel speed sensor
5DA5 Front right wheel speed sensor. Double frequency
5DBO Rear left wheel speed sensor
5DB1 Rear left wheel speed sensor
5DB2 Rear left wheel speed sensor. Pulse gear faulty
5DB3 Rear left wheel speed sensor
5DB4 Rear left wheel speed sensor
5DB5 Rear left wheel speed sensor. Double frequency
5DCO Rear right wheel speed sensor
5DC1 Rear right wheel speed sensor
5DC2 Rear right wheel speed sensor. Pulse gear faulty
5DC3 Rear right wheel speed sensor
5DC4 Rear right wheel speed sensor
5DC5 Rear right wheel speed sensor. Double frequency
5DFO Return Pump
5DF2 Control unit. Internal fault
5DF4 System voltage less then 9 volts
5DF5 Control unit. Internal fault
5DF7 System voltage greater then 18 volts
5EOO End of line test
5E01 End of line test
5E02 End of line test
5E03 End of line test
5E04 End of line test
5E05 End of line test
5E06 End of line test
5E07 End of line test
5E08 End of line test
5E11 Control unit. CAN controller: CAN fault CAN bus OFF
5E14 CAN connection to DME/DDE (DSC lamp on until ignition reset)
5E16 CAN connection to instrument cluster
5E18 CAN data fault from DME/DDE
5E19 CAN data error from DME/DDE (DSC lamp on as long as error is present)
5E1A CAN data error from DME/DDE (DSC lamp on until ignition reset)
5E1E Steering angle sensor. CAN failure
5E1F Vehicle identification number different
5E20 Pressure sensor
5E21 Pressure sensor
5E24 Pressure sensor
5E26 Control unit. Voltage supply sensors
5E2F Control unit. Internal fault
5E30 Transverse acceleration sensor
5E32 Transverse acceleration signal
5E38 Rotation rate sensor
5E3C Rotation rate signal
5E40 Steering angle sensor. Not Plausible
5E43 Steering angle sensor. Internal fault
5E4E DSC sensor offset
5E4F Continuous control
5E58 Control unit. Incorrect variant
5E59 Coding Error
5E5B ASC/DSC button
5E5C Initialise Run Flat Indicator; See owners handbook
5E5D Brake fluid level Sensor
Old Dec 10, 2016 | 01:48 PM
DDC92's Avatar
DDC92
Did you ever fix the tire warning light? I have a 2003 without DSC and you appear to have the close to the same problem I have. Originally had Brake, ABS, low tire lights along with service engine and airbag when bought the car but now down tire warning. Original had no connection to ABS and replaced the controller/hydraulic unit which allowed me to find bad speed sensor. With new sensor brake and ABS cleared but low tire stayed lit and reset does nothing using button or diagnostic software. ABS provides 5E14 and 5E15 on MK60 module. When monitoring wheel speed sensors while driving they appear to report the same speed. Running INPA to trouble shoot. FYI My airbag left side was due to broken wire under seat and drivers side from bad clock spring (no horn isolated it) engine is longer story ending in cam shaft replacement.
Follow up: Reprogrammed the ABS module with NCSExpert, apparently used module from Ebay was programmed for DSC, Cleared tire warning light and 5E14/15 faults.
Ygritte
Jan 22, 2019 06:48 PM
1004ron
Mar 22, 2016 09:39 AM
JWA
Mar 21, 2016 02:57 PM
JWA
Mar 20, 2016 04:30 PM
mrice0118
Mar 16, 2016 05:19 AM
