R50/53 Pollen on inside of headlights
Old Apr 18, 2016 | 09:38 AM
davisflyer's Avatar
davisflyer
After washing my car i notice that it looked like some pollen had built up on the headlights, but after closer inspection, it's now apparent that it is on the inside of the lens. Is there any way to disassemble them for cleaning or do I have to buy new lights??
Old Apr 18, 2016 | 10:02 AM
Saltysalt's Avatar
Saltysalt
you would essentially be doing the "joey mod". just minus changing anything. headlamp assembly in the oven at X deg for X time, glue softens and can pull the lens off. get new butyl glue and stick back on
Old Apr 19, 2016 | 07:46 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yes, you'll want to take everything off the headlight and remove the bulbs and bake them to loosen up the sealant that keeps the lens to the housing. Then you can open them up and customize the inside at the same time if you'd like. I did this and blacked out my headlight housing and put a slight flake over the black. Just make sure you do a good job with sealing them back up so that nothing can get inside. Someone did it HERE that you can check out.
888.280.7799 | 6am - 5pm PST
Michael Nicely
Aug 1, 2016 10:31 AM
Dat_Carguy
GP Talk (2006)
May 12, 2016 04:59 PM
vetsvette
Apr 20, 2016 05:34 PM
67morris
Apr 19, 2016 07:59 PM
fenderpicks
Apr 16, 2016 08:08 PM
