I'm in need of the trim piece pictured below. The piece currently on the car is slight warped and will not stay put. I've been unsuccessful in finding one online and have been equally frustrated with junkyards. Can anybody point me in the right direction?
I think that the part number is 51317054068 Top Rear Window Cover. You can find it on realoem.com under "Vehicle Trim, Exterior Trim/Grill, bottom illustration. There are also 3 separate part number clips associated with this. ECS Tuning has them in stock for a little over $20 plus the $2 clips. If you call them they could probably help you with DIY.
For the R50 and R53 it's #1 below on the diagram, which is HERE. There are 2 part numbers listed, but I can confirm fitment if you'd like if you send me the last 7 digits of your vin. Clip for the center, #3 below is HERE. Clip for the left #2 HERE and the other clip for the right #2 HERE.
