R50/53 Power steering issue?
Old Apr 8, 2016 | 12:23 AM
hamerg's Avatar
hamerg
I have having an issue with my steering. The effort is high and the wheel does not want to return to on center. I am guessing the pump is bad, and this car (05 cooper) is not covered by the recall as I called the dealer. Before I go and order a reman pump, I just want to make sure it is not another issue. To summarize, the steering effort has increased and when I come out of the corner I have to bring the steering back to center myself for the most part. Another way to describe is that the steering is a little jerky.
Thanks for any input,
George
Old Apr 8, 2016 | 04:45 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Enter your VIN on MINI's open recalls page HERE to find out for sure, but I believe your car is within the window (cars made between 2002-2005) to qualify for the recall.
You can read more about it HERE.
Old Apr 8, 2016 | 05:34 AM
Passatrs4's Avatar
Passatrs4
It might not be your power steering pump. I am currently having the same issue, so i was perusing the forums and you might want to check the lower steering shaft and the condition of the u joints. This might save you from ordering an expensive part that is not needed to be replaced.
https://www.northamericanmotoring.co...mc-w-pics.html
Old Apr 8, 2016 | 07:41 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Did you ever hear any noises from the power steering pump? I would check if the power steering pump is turning on. If not, check power and ground to the pump, if present, the pump could be faulty.
888.280.7799 | 6am - 5pm PST
Old Apr 8, 2016 | 10:28 AM
rt808's Avatar
rt808
Power steering recall
+1.... Mine is 02 and bringing-in my car in a week for power steering pump, although no issue yet at 57,000 miles, better safe than never, its free of charge.
Old Apr 8, 2016 | 11:36 AM
hamerg's Avatar
hamerg
That does sound more like my problem, thanks for the heads up. Now as far as expensive parts go, PS Pump is about $300 and the shaft looks to be $275! I will look it over tomorrow afternoon and chime in with what I found.
This is why I ask first and thanks to all the spoke up. I did check the warranty and was told by Mini that my car was manufactured after the change.
Old Apr 8, 2016 | 03:46 PM
Shawnnn's Avatar
Shawnnn
If it's the shaft u-joint just spray it with wd40 or any other lubricant. Ive sprayed mine twice after it froze up 2 years ago with no issues.
TxMINIMama
Mar 7, 2016 09:15 AM
supermonkey
MINI Camera and Video
Feb 27, 2016 01:43 PM
Qbert
Feb 22, 2016 05:11 PM
jpinkerton
Feb 19, 2016 04:41 AM
smwzuu
Feb 18, 2016 05:02 AM
