R50/53 Rear suspension knuckle trailing arm
Old Apr 6, 2016 | 02:38 PM
HaveATank's Avatar
HaveATank
I was wondering do they have aluminum one of this?
I saw someone say they have aluminum versions of this or are this R56 versions that just bolt on to the R53 and if it just the R56 once what else would i need to make this work on an R53?
Old Apr 7, 2016 | 07:08 AM
Some take the R53 GP and switch them. Edge had them and has done it.
Just copy and paste the 11 digit part number into our site.
https://www.northamericanmotoring.co...s-it-take.html
Old Apr 8, 2016 | 09:30 PM
HaveATank's Avatar
HaveATank
Thanks for the reply. read thru the post though it wouldn't be a straight swap.
Old Apr 8, 2016 | 10:52 PM
RB-MINI's Avatar
RB-MINI
Not quite a straight swap. You'll need to make sure you have A few small fasteners which are different, or considered one time use, R53 to R56 strut bushings or R56 rear struts, and R56 swaybar end links. I think some people use their old end links by grinding down part of the R56 arms.
Old Apr 9, 2016 | 05:12 AM
cristo's Avatar
cristo
Alliance Member
A little lighter, but if you do it, be very careful with the threads for the bolt for
the bottom of the shock, as aluminum can strip much more easily than steel.
Old Apr 9, 2016 | 06:42 AM
HaveATank's Avatar
HaveATank
typo with the wouldn't.
If it was a straight swap i would do it. I just went a found the
R53
Rear Trailing Arm Bracket R+L
Rear Trailing Arm R+L
Rear Subframe Crossmemeer
Adjustable Rear endlinks
H-Sport Sway bar
Rear Trailing Arm Bracket Bushings R+L
R56 JCW BBK and R56 Parking brake lines
Doing something similar for the front. I Going to start one of does Build threads soon.
Old Apr 11, 2016 | 11:15 AM
Welcome, yea there is some work.
johntotah94
Jan 20, 2018 11:09 PM
mikbau
May 6, 2016 07:47 AM
gerry2153
Mar 31, 2016 07:23 PM
mcn02
Mar 17, 2016 03:59 PM
Lopez421
Mar 15, 2016 09:30 AM
