Does anyone know of a plastic option to replace the metal oil filter cap? Looks like the threads on the oil filter block are slightly stripped and I am hoping that a plastic one might be a little more easy to thread.
If I recall right, they are sold, the entire unit,top and bottom as one part....good time to change the seal where it mounts to the block....they leak after a bit....
If you put the filter cap on..and turn it BACKWARDS till you feel the threads line up...then go forward, it makes screwing it in much simpler.
