R50/53 Mini Cooper Acceleration noise
Old Mar 23, 2016 | 10:36 AM
Sandijs Shifers's Avatar
Sandijs Shifers
Hello!
I have a little problem with my Mini Cooper R50 2005 (automatic). When I accelerate hard I get a high-pitch noise. When it is cold outside the noise disappears. Sometimes when I start the car in the morning the sound does not appear from the start, but after the car has warmed up (after about 5 minutes) the noise comes back again. This high-pitch noise seems to appear only in the lower gears. The performance of the transmission has been great so I think that is not the problem? Here is a little video that I made so it would be more clear –
Also when I accelerate lightly the noise isn't there.
Does anyone have any idea what the problem might be?
Thanks!
Old Mar 23, 2016 | 11:17 AM
Sounds like transmission noise or maybe an axle ( but usually its all the time ), hard to tell. What side of the engine is it coming from ?
Old Mar 23, 2016 | 11:51 AM
Sandijs Shifers
To me it sounds like the sound is coming from the passenger side (the right side). When I called MINI and said that I had an issue with this high-pitch sound, they did an inspection and found that the right output shaft had an issue, but I am not sure if that is the actual problem that is making this sound? Could it be?
Old Mar 23, 2016 | 12:46 PM
ZippyNH's Avatar
ZippyNH
Well....you had a mechanic tell you you have an issue....
Now you say you hear a noise....
Related....think?
Nobody likes to spend unnecessary $$ on a car...but once you have one known issue...troubleshooting anything else becomes exponentially harder, since the bad part can make others do abnormal things, or even make others fail, making repairs more $$$$.
Old Mar 23, 2016 | 12:58 PM
Sandijs Shifers
Thanks for the comment ZippyNH. I agree with you 100%, but because I live in a small country the output shaft will arrive only in late May. So I was just wondering if anyone had a similar issue, I thought maybe it is something else that is making the sound.
Old Mar 23, 2016 | 01:41 PM
I would check that output shaft for sure , we ship world wide also and very fast.
Have you messed with the axle up on the rack, moved it back and forth?
Old Mar 23, 2016 | 02:13 PM
Sandijs Shifers
The axle itself looked good. I actually did move it back and forth and everything looked and sounded just like it is suppose to. I will probably take the car to my friends service center to see what he thinks could be the issue.
Tata Steva
Mar 22, 2016 11:24 AM
GimmeBoost
Mar 8, 2016 12:35 PM
Qbert
Feb 22, 2016 05:11 PM
Feb 22, 2016 02:54 PM
air1mtt
Feb 22, 2016 11:56 AM
