New mini
Old Mar 23, 2016 | 05:29 AM
Yazzz's Avatar
Yazzz
New mini
Just got a 2013 mini cooper..what size wheels is better and how to add bluetooth?
Old Mar 23, 2016 | 07:39 AM
Hello and welcome. I like the 17" for daily and summer wheels, keep the smaller size wheel that you have for winter and mount some snow tires on them, when you go bigger you will have a rougher ride. So watch the 19"+ sizes.
OEM wheels options
https://www.ecstuning.com/Mini-2013-...ls/OEM_Alloys/
OR
NM Engineering options
https://www.ecstuning.com/Mini-2013-...market_Alloys/
For bluetooth options see here.
Also check if you have bluetooth , even though you have the buttons, on the screen in the center it will pop up in the menu, if you dont have it , it was not ordered. No factory retrofit upgrade for the 2011+ Gen 2 MINIs. There is one for 2007-2010. Also linked are some other options.
https://www.northamericanmotoring.co...-usb-port.html
Only other option is to transplant a head unit from another MINI that has the bluetooth option. kind of a big job.
Old Mar 23, 2016 | 08:40 AM
3lusive's Avatar
3lusive
Depending on what you want bluetooth for, I have a device that plugs into the audio jack and is powered by usb. I can connect via bluetooth to this device which transmits the audio through the car speakers, and it works for both phone audio and music. The quality of phone is better than factory bluetooth too according to people I've chatted with using it. The device comes with a wired remote to change tracks, pick up calls, etc and it's small enough to hide somewhere on the side of the center console if you want.
Old Mar 24, 2016 | 08:00 AM
Yazzz's Avatar
Yazzz
Thank you so much for such a helping suggestion im so new in mini and trying to figure out how to use it..can i see the inside of your mini? And the bluetooth you are using 😊
Old Mar 24, 2016 | 01:06 PM
3lusive's Avatar
3lusive
I'm using this guy:
Amazon.com: Mpow Streambot One Bluetooth 4.0 Hands-Free Car Kit / Bluetooth Audio Music Receiver for Car Stereo Supports Voice Control: Cell Phones & Accessories Amazon.com: Mpow Streambot One Bluetooth 4.0 Hands-Free Car Kit / Bluetooth Audio Music Receiver for Car Stereo Supports Voice Control: Cell Phones & Accessories
there's plenty of choices on amazon that do similar things. This one can pair two phones at once which I never use. I liked that the charger comes with an extra USB port which comes in handy to charge my phone.
Note that you'll have to buy a ground loop isolator:
Amazon.com: PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator Works with iPod/Zune/iRiver and Others: Automotive Amazon.com: PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator Works with iPod/Zune/iRiver and Others: Automotive
This is used to get rid of the hissing/buzzing noise that seems to happen without it. It will also slightly lower the output volume from the phone but you can just up the audio volume in the car. I'll have to take some pics later and post them up for you!
Old Mar 24, 2016 | 08:23 PM
BLokE_W_a_MINI's Avatar
BLokE_W_a_MINI
even though I prefer original equipment, The Plug and Play (like parrot, etc,...) are the easier and actually better options than factory Bluetooth,... one cannot simply swap radios, since those are vin specific and programmed for the individual vehicle they are installed
Old Mar 27, 2016 | 09:59 AM
Mini1011's Avatar
Mini1011
I like these motegi sp10. There pretty cheap too. I prefer 17's anything bigger is a pretty rough ride I think.
Old Mar 29, 2016 | 06:27 AM
Yazzz's Avatar
Yazzz
Still undecided about on getting 17..im thinking on 14 or 15 and using coilovers..any idea??
Old Mar 29, 2016 | 06:46 AM
17" are a great size for the summer,. then run 15" in the winter. 14" or too small.
Old Mar 29, 2016 | 06:53 AM
Yazzz's Avatar
Yazzz
17 with coilovers or no?
Old Mar 29, 2016 | 06:56 AM
yes, they will be fine, just what width if you go OEM and NM aftermarket on coilovers most will be fine. Unless you are getting some aftermarket coilovers that are slammed.
Old Mar 29, 2016 | 07:03 AM
Yazzz's Avatar
Yazzz
Where can i find those coilovers?
Old Mar 29, 2016 | 08:09 AM
R56 MINI Cooper ( NON S ) Coilover options:
https://www.ecstuning.com/Mini-2013-Cooper-R56-Base-Coupe-L4_1.6L_N16B16A/Suspension/Coilovers/
MarcSellsMiami
Mar 31, 2016 09:16 PM
MINI -in-Black
Mar 10, 2016 10:20 AM
MINI -in-Black
Mar 10, 2016 10:17 AM
ultrahuck
Mar 3, 2016 05:37 AM
Feb 22, 2016 02:54 PM
