Ok I might be crazy but, since the Jb+ works on the MAF sensor and the race chip works on 2 other sensors ( assume MAP) can you run them in tandem or is there any risk??!!
Update... Jb+ and sprint booster in tandem!! Holy $&@$..
The car pulls almost too hard for my needs and when is sport mode I can't believe this is my mini!!!
Update... Jb+ and sprint booster in tandem!! Holy $&@$.. The car pulls almost too hard for my needs and when is sport mode I can't believe this is my mini!!!
JB and SB is fine, some of customers do Manic and SB. I would not do two tunes together. After doing an ECU flash, I got rid of my SB, made driving a manual in parking lots horrible
mQubed Motorsport Manic Tuning Dealer
__________________ 2013 GP2 #295, 270whp/310wtq, KO4 47mm Turbo, 18" NM Wheels, Alta intake, Manic Stage III+, HFS-3 Meth, 30% E85 Blend, Forged IC, Alta Hot Pipe, P&P/Ceramic Exhaust Manifold, m3 Extreme Ceramic DP, Vibrant mid res, 4" Double walled Tips, WMW/KW V3 CO, Alta Rear CA, CREE Fogs, Black out F/R Rings and Gas Cap, M7 CF Front Splitter, and No Stickers. MORE TO COME!! Previous 04Triple Black 17% Alta, MM Air/H2O, CAI, OBX Header, FBT Head, Shrick Cam, 234whp
MAP sensor attenuation does not work on the platform. That RaceChip won't do a thing for you on this platform JB+ on or not.
Then how does the race chip work on the N18?? It's not very clear on their website but it says it hooks up to 2 sensors one right before the manifold and another one!!
It just doesn't add any power. RC is a generic analog only module they fit to every turbo model under the sun. That tuning technique works on some vehicles and not on others. They don't bother to determine the difference.
