R50/53 #3 Misfire help
Old Feb 18, 2016 | 03:06 PM
Derek Kentrup's Avatar
Derek Kentrup
#3 Misfire help
At about 4k in 6th gear on the highway I lost most power and CEL began to flash. I limped it home and checked the code - misfire on #3. Replaced all plugs wires and the coil. When i removed #3 plug I noticed the tip of the electrode was missing. When i started the car the code came right back and the miss is just as bad as before. I'm gonna do a compression check this weekend but I was wondering if there was anything "mini specific" that I should know about? Thanks in advance for any help
Old Feb 18, 2016 | 05:27 PM
David.R53's Avatar
David.R53
Maybe you have a bigger problem that caused the spark plug to erode. Lean on one cylinder --> maybe a bad or clogged injector?
Old Feb 19, 2016 | 08:19 AM
Unbreakable Lump's Avatar
Unbreakable Lump
Please post a photo of the damaged plug. A lean condition in that cylinder is certainly a high probability.
If the tip burned off, there's a chance that you also burned a hole through the piston due to pre-ignition, so yes do a compression test.
Old Feb 19, 2016 | 10:07 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Some suggestions to check over as well HERE. Compression test is always a good idea.
888.280.7799 | 6am - 5pm PST
Old Feb 19, 2016 | 12:03 PM
NotMyMini's Avatar
NotMyMini
How many miles on the Mini? Is it S or nonS?
Do the compression test and good luck.
ej
Feb 13, 2016 03:23 PM
BushOner
Feb 8, 2016 12:26 PM
nbowncrawford
Feb 8, 2016 08:10 AM
mmdouglas
Feb 4, 2016 06:36 AM
bas1c
Jan 30, 2016 02:36 PM
