R56 How to check the timing
Old Jan 24, 2016 | 04:12 PM
U.S.A. Ranger's Avatar
U.S.A. Ranger
I have a 2008 MCS, N14. Does anyone know if there is a way to check the timing without removing the valve cover? It's running great and not throwing any codes. I would just like to know if there is an easy way to check the timing.
Old Jan 24, 2016 | 07:13 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
No you have to install the cam blocks and lock the crank to know.
Old Jan 25, 2016 | 11:57 AM
nkfry's Avatar
nkfry
You can check it manually with timing blocks, or if you have access to an expensive scan tool you can watch cam/crank correlation.
Easiest way is to check with the valve cover off though.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
proximal
Feb 16, 2016 09:42 AM
mcn02
Jan 31, 2016 01:41 PM
Jan 6, 2016 02:20 PM
nlipscy
Jan 5, 2016 10:48 AM
bradyjohnson08
Jan 2, 2016 05:25 PM
