R50/53 Cam Decision?
Old Jan 8, 2016 | 02:57 PM
JaysinStrife's Avatar
JaysinStrife
Cam Decision?
Who all is running cams? What are you guys running? I was looking at the RMW 246, but I do plan to tune and my car so I was curious if the 250 was the way to go. I like the idea that the cams are not re grinds, however I'm open to any advice or experience everyone else has had with cams. Currently I have a DDM intake, and a Magnaflow exhaust. I do plan to run a 16 or 17% pulley, and at least do JCW 380cc injectors, if not RMWs. The car more than likely won't be tracked but I may get a wild hair.
Old Jan 8, 2016 | 03:04 PM
IQRaceworks's Avatar
IQRaceworks
I'm sure some others will chime in soon.....but from everything I've read/seen/heard.......swapping to an aftermarket cam will get you a little more power up top (which comes in handy at the track), but almost always there will be a loss in power and torque down low (which stinks for street driving). The mini's are already pretty gutless at low RPM's, I can't imagine having less power down low.
But who knows....maybe there are cams out there that will give you power and torque throughout the rev-range...not just at really high rpms.
Do the 17% pulley first......that's the best bang for the buck mod by far. Don't waste your money on different injectors unless you are going to be doing stuff like headers, big valve head, camshaft.....
Old Jan 8, 2016 | 09:55 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I agree as I never liked regrinds. We've installed and used all different brands of cams, heck even have a shelf of cams that failed or were not ground correct. So we went out and go our own from brand new billet blanks with extra lift and offer a mild and race cam. Our mild is great for a daily driver as it give more torque low and mid range, plus still idles fine. Our race gives more, but idle bump or tuning is needed to make it idle.
http://www.waymotorworks.com/way-mil...t-r52-r53.html
http://www.waymotorworks.com/way-rac...t-r52-r53.html
Old Jan 9, 2016 | 04:57 AM
IQRaceworks
Way, could you post up a before/after dyno graph of a mini that got one of the mild and/or race cams? It would be interesting to see how they compare to the stock cam.
Thanks!
Old Jan 9, 2016 | 06:05 AM
jeffster06's Avatar
jeffster06
Thanks!
I'm running ways race cam have had it in for about 6 months now. List of mods are as follows:
Megan header (no cat)
Alta intake
15% pulley
2.5" exhaust straight back (baffle pack and glass pack inline)
Quaife diff
WMW quick tune (plus he upped my idle later the cam did not like stopping at Red lights)
ATI super damper
Detroit tuned bpv
Here is my Dino chart, the Temps between the days were about the same and these runs were taken a week apart.
Also I did the dyno pulls in June, my butt dyno says that the colder fall weather is probably pushing me into the 200 territory.
Last edited by jeffster06; Jan 9, 2016 at 06:16 AM. Reason: More info /stupid auto correct
Old Jan 9, 2016 | 06:09 AM
bavmotors's Avatar
bavmotors
Originally Posted by jeffster06
I'm running ways race cam have had it in for about 6 months now. List of mods are as follows: Megan header (no cat) Alta intake 15% pulley 2.5" exhaust straight back (baffle pack and glass pack inline) Quaife diff WMW quick tune (plus he upped my idle later cam did not like stopping at Red lights) ATI super damper Detroit tuned bpv Here is my Dino chart, the Temps between the days were about the same and these runs were taken a week apart.
those are good numbers, have any driving vids?
Old Jan 9, 2016 | 06:14 AM
jeffster06's Avatar
jeffster06
Nothing yet, probably after motd. I would have done video at the dyno but this place had me run my car.
Old Jan 9, 2016 | 06:23 AM
IQRaceworks
Wow..that's impressive! 25hp gain.....and more power and torque everywhere. With that being the case for the race cam....why would anyone go with the mild cam?
Just out of curiosity.....what happened to your MPG?
Old Jan 9, 2016 | 06:32 AM
jeffster06's Avatar
jeffster06
I think the mild cam would be more street able, the race cam takes some getting used to without a full tune. My gas milage went down about 2 mpg. But it's not my daily anymore so I don't mind lol.
Old Jan 9, 2016 | 08:15 AM
David.R53's Avatar
David.R53
I put on a street cam (along with other mods and a tune) thinking it would help at the low end, but the overall result follows the same pattern as what is posted above - Torque and horsepower are essentially the same as stock at 3000 rpm, and increase proportionally going to higher rpm, up to 210 hp at redline.
One nice feature in my setup is the torque and horsepower both increase all the way up. So, nice butt feeling (hmm, doesn't sound quite right).
MD11Driver
Mar 11, 2016 07:08 AM
audio131
Dec 12, 2015 05:55 AM
Clutch Wotan
Dec 12, 2015 12:55 AM
WayMotorWorks
Dec 11, 2015 10:06 AM
arinthyn
Dec 10, 2015 06:23 AM
