Clutch Super Kits for MINI R50/R52/R53 - Save On Your Next Clutch Job Today!
Old Jan 7, 2016 | 11:08 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
With our new clutch super kits you get everything you need to replace your clutch all at once. Most of the parts contained in the kit are either OEM or Genuine MINI parts. If you are spending the time and effort to do this job, you might as well make sure that you are replacing and fixing every piece that might need attention, while you have access to it.
CLICK HERE to purchase yours today!
*Picture may vary from product*
888.280.7799 | 6am - 5pm PST
Old Jan 18, 2016 | 11:58 AM
PelicanParts.com
Vendor
bump.
Old Feb 25, 2016 | 09:24 AM
PelicanParts.com
Vendor
bump!
Old Feb 25, 2016 | 09:35 AM
xsmini's Avatar
xsmini
any kits that include flywheel too? (single mass conversion)
Nik
Old Feb 25, 2016 | 09:57 AM
PelicanParts.com
Vendor
Nik
Unfortunately our clutch kits do not include the flywheel and that will need to be added separately. However, the nice thing about our kits is that you can add them to the cart and once you view it in the cart you can delete single items out of the kit that you do not want. So if you're wanting the conversion kit you can add this kit HERE to your cart and then go to it and delete 21-20-7-551-383-M37. Then you can add the conversion kit HERE to the cart to replace the clutch you deleted out. You'll also want to delete out the 8 fly wheel bolts 11-22-7-560-579-M26 and the 6 pressure plate bolts 21-20-7-520-449-M26 as those are included with the flywheel conversion kit.
Let me know if you need any help or have any questions.
Old May 12, 2016 | 08:19 AM
PelicanParts.com
Vendor
Bump!
Old May 14, 2016 | 05:17 PM
doomsdaybob's Avatar
doomsdaybob
I'm seeing two different single mass conversion kits on your site, one for $502 and one for $526? What is the difference between the two?
Old May 16, 2016 | 07:58 AM
PelicanParts.com
Vendor
Hello! I typically link individuals to the 52151203-INT kit as it's cheaper. The only difference between the two is that they both come from different suppliers. We just have better pricing on the kit that comes from that supplier. Let me know if you have any other questions.
Old Nov 30, 2016 | 08:05 AM
PelicanParts.com
Vendor
Bump!
Old Jan 17, 2017 | 10:34 AM
PelicanParts.com
Vendor
Bump!
MINIdame
Mar 25, 2016 06:12 AM
Emnotek
Jan 13, 2016 11:49 AM
Dec 3, 2015 11:18 AM
Dec 3, 2015 09:59 AM
