R56 New boost gauge install
Old Dec 30, 2015 | 01:52 PM
SpuuDy's Avatar
SpuuDy
Hey guys just got my boost gauge hooked up, it's reading about 9psi bone stock. Is that what you guys are getting and where are you taping the backlight wire into? Thanks
Old Jan 2, 2016 | 05:36 PM
oldbrokenwind's Avatar
oldbrokenwind
My ProSport gauge has 4 wires --- the obvious power, ground, and nite lighting, and a 4th wire to change display color. The wiring procedure is a couple pages long and unique to this ProSport model. If you don't have a set of instructions, I suggest you contact the mfgr for a set. They are often available as a download.
Old Jan 2, 2016 | 09:23 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
The backlight control on the Mini is not just a simple voltage control, it is pulse width controlled so unless your gauge is set up for that you'll need an external circuit.
A bunch of info on gauge install and wiring here: https://www.northamericanmotoring.co...r-dummies.html
Old Jan 2, 2016 | 11:11 PM
SpuuDy's Avatar
SpuuDy
Thanks for the help, I got me a cheap Equus gauge from the local autozone . I typed into google gauge install instructions for the r56 and found a how to from Alta. The guide says to pull the center up out of the car and unplug the cigarette lighter and to tap into those wires. (Red power, brown ground). I might just go along with this (the only thing about it is that he light will always be on while driving). I'll post pics later of the gauge.
Old Jan 6, 2016 | 10:54 PM
NW Cooper S's Avatar
NW Cooper S
Stock 2008 S auto, I see 13lbs when I hammer down and 15lbs peak in higher gear/load scenarios. Turbo muffler delete and knn typhoon intake kit with factory fresh air setup. No other mods I'm in Washington state and 100ft above sea level.
Old Jan 7, 2016 | 07:02 PM
SpuuDy's Avatar
SpuuDy
I see peak at higher gears too like shifting into 4 low rpm. But mine is like 11psi peak. Mostly it stays around 8psi. (I'm bone stock and in St. Louis) They say the turbo muffler delete adds 1-2 psi so maybe that's the difference
Old Jan 7, 2016 | 09:27 PM
NW Cooper S
Difference could be elevation, inconsistency in sensors, and or accuracy of gauges.. 11psi peak is pretty typical from what I read here on NAM mostly.
15psi I've only hit in top of 4th gear on this one stretch of road. Strange I've yet to see 15psi in any other condition. The overboost function (mashing gas pedal quickly from at about 1/2 throttle) will typically see 13 psi and occasionally 14psi in 3rd gear and up.
fradaj
Sep 10, 2017 08:18 PM
rosaymaan
Electrical
Jan 13, 2016 11:10 PM
rachy-s
15
Jan 11, 2016 02:47 PM
minigen
Dec 29, 2015 05:37 AM
audio131
Dec 20, 2015 10:00 PM
