R56 Eninge Oil pan damage - question
Old Dec 21, 2015 | 05:57 PM
miniauto's Avatar
miniauto
Hi all!
I managed to hit a bump the other day that dented my engine oil pan from below. Aside from a tiny crack at the edge, resulting from the incident, the oil pan is still sealed and tight.
It does however have its (inward, to the car's center) bottom dented up into it some.
I was able to seal the crack with JB weld.
Now I started it up and it sounds as if something is mechanically hitting something else. I looked at diagrams but can not get a clear picture so here my question:
Is there something that protrudes into the oil pan from above that might be grinding against the more shallow oil pan bottom now?
I will add pictures tomorrow.
Edit 1: Car is a R56 2008 Mini Cooper Hatchback. I reside in the USA.
Edit 2: I realize that the header has "engine" spelled wrong but I have no option to correct it.
Old Dec 21, 2015 | 07:31 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
the oil pump pickup does come pretty low, so it's possible it is hitting it.
We sell new oil pans if you need, and also have a couple good used ones.
Old Dec 22, 2015 | 06:34 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If you decide to remove the oil pan we have a DIY that may be of assistance.
888.280.7799 | 6am - 5pm PST
Old Dec 22, 2015 | 06:35 AM
Need pics, how hard did you dent it ?
Get a new oil pan and seal. Call your insurance and see it they will cover it. Might hit s bad it knocked the oil pickup / strainer.
I would also get a skid plate for a little extra protection.
https://www.ecstuning.com/Search/SiteSearch/ES2840603/
Old Dec 23, 2015 | 10:57 AM
ashchuckton's Avatar
ashchuckton
I'd sure as heck replace that oil pan. It is quite likely that crack will migrate over time. When it starts leaking if you don't notice it right away it will cost you an engine. JB Weld really?
Old Feb 13, 2016 | 11:40 AM
wdh's Avatar
wdh
Also dented mine. Where is the oil pickup located in relation to the dent?
Lex2008
Aug 9, 2024 12:54 PM
studio47
Dec 4, 2015 08:46 PM
TXcooper04
Nov 25, 2015 07:53 AM
Danske
R60/61 Cooper S Drivetrain
Nov 24, 2015 11:03 AM
got_mini?
Nov 23, 2015 06:18 PM
