R56 Stall issue at idle
Old Dec 5, 2015 | 10:59 PM
t0mthebomb97's Avatar
t0mthebomb97
Stall issue at idle
Hey all,
I have a 2010 Mini justa and I recently changed the water pump and water pipe (the pipe that connects the water pump to the thermostat), and since reassembly I have run into some issues. First of all, I did have to remove the thermostat and ecu harness in the process of replacing the water pipe, and I did pay careful attention to which sensors/connectors went where etc. Now, when I start the car, everything seems normal until about 3 seconds after startup then the engine stalls. It will remain running if i apply light throttle and will maintain constant rpm as long as throttle is applied. No CEL or check lights of any kind. Wondering if anybody else has seen similar issue? Possible pcv leak/bad sensor? Any help would be more than appreciated!
Old Dec 8, 2015 | 09:28 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I'd check for a vacuum leak.
888.280.7799 | 6am - 5pm PST
Old Mar 14, 2024 | 03:17 PM
HermanG's Avatar
HermanG
Originally Posted by t0mthebomb97
Hey all,
Hi, my mini went in to the garage and had 2 hoses replaced and is doing exactly this apparently now. What was the solution in the end as they seem to be stuck as no error messages, everything showing as up as being fine.
guruerror
Dec 13, 2019 04:53 AM
greentrees
Jul 14, 2016 08:18 PM
Pepelx
Dec 30, 2015 05:08 AM
AbsoluteAuto
Jun 5, 2014 12:03 PM
ACTE
Mar 5, 2014 11:04 AM
