R56 Replaced burned bulb, still getting indicator
Old Dec 5, 2015 | 04:40 PM
jeph swift's Avatar
jeph swift
Hi all!
I'm new here. I just picked up my first Mini on Thursday, loving it so far!
Have to get a new TPMS sensor installed to get the light to go out. and now I have a "exterior light failure" indicatory, even after replacing the burned out turn signal side repeater. It lights up and works, but the light out indicator is still on. There aren't any other lights out.
Is there a way to reset the light indicator?
Thanks,
Old Dec 5, 2015 | 04:58 PM
AZdsrt's Avatar
AZdsrt
Are you SURE you don't have another burned out light somewhere? Lots of threads on this subject, Mini has some lights in odd places (ie on the bottom side of the doors)..
Old Dec 5, 2015 | 05:08 PM
jeph swift's Avatar
jeph swift
Yeah, both puddle lamps, front + rear turn signals, brake lights, reverse lights, DRLs, foglights, left and right side repeaters (i just replaced the right side repeater), both front and rear side markers, both license plate lights are all working fine.
The only one I can think of that I just thought of would be the rear fog light, but I don't even know if this car is outfitted with that. I guess there's only one way to find out lol
Old Nov 14, 2023 | 05:15 PM
ptkacik's Avatar
ptkacik
I’m getting this error code and it is a bulb in the right tail light. I’ve replaced the bulb, twice. The contacts looks shiny silver and clean. The light out code is good for a day or two and then comes back on. I’ve used contact cleaner and bulb grease but they don’t seem to help.
Any ideas?
Peter
Old Nov 15, 2023 | 06:11 AM
maccoder's Avatar
maccoder
I am not sure if the warning light illuminates for interior bulbs, but if so maybe it's one of those? Besides the usual cabin lights, there are lights in footwell and cargo area. Just a thought...
Old Nov 15, 2023 | 06:12 AM
ptkacik's Avatar
ptkacik
I use a Foxwell scanner. It tells me exactly which bulb is the problem.
Peter
Old Nov 15, 2023 | 06:29 AM
hndle's Avatar
hndle
I get an error about left upper brake light now and then. I removed the assembly and see the way the contact lines are not the greatest design. Sometimes just smacking the assembly works, but I would say reach in and twist the bulb left and then right to restore. Clear the stored code with Bimmercode.
Old Nov 20, 2023 | 10:00 AM
ptkacik's Avatar
ptkacik
I removed the bulb holder and noticed that the shiny silver contact was slightly burnt away. How curious. I filed it smooth and bent it slightly to increase contact pressure.
The bulb light has finally gone out. Hooray!!
Peter
SammyCooper
Nov 10, 2015 01:27 PM
AvianMan
Nov 3, 2015 11:00 AM
Oct 29, 2015 07:41 AM
Oct 27, 2015 01:46 PM
Oct 27, 2015 01:45 PM
