OutMotoring 12mm Spacer Install Question
Old Dec 3, 2015 | 12:15 PM
MothAudio's Avatar
MothAudio
OutMotoring 12mm Spacer Install Question [before / after pixs]
I have a set of 12mm hub-centric spacers being shipped from OutMotoring for my R55 *. The boys @ Discount Tire won't touch them so I have an install question. What's the consensus on applying a thin coat of anti-seize or MolyLube on the hub and around the edge of the spacer to reduce it becoming stuck to the rotor?
I've read conflicting posts on the merit of applying these substances. Will post before / after photos. TIA.
* On Michelin Premier A/S 205/50/16 coupled to [OEM] R94 wheels.
Old Dec 3, 2015 | 12:28 PM
GEMSTER's Avatar
GEMSTER
The spacer usually doesnt get stuck on the hub since its aluminum.
Though for a preventative measure, I put anti-seize on the centering ring on the hub. No problems.
Old Dec 3, 2015 | 12:44 PM
MiniRoadstah's Avatar
MiniRoadstah
Never have heard of problems applying anti-seize and have used it on aluminum wheels for many years without complication. Can't see how it would be different with a spacer. Just use a very small amount. A little goes a long way.
Old Dec 3, 2015 | 01:10 PM
MothAudio's Avatar
MothAudio
That's what I meant to say. Thanks for clarifying.
Old Dec 5, 2015 | 04:24 PM
09OBMC's Avatar
09OBMC
Yes use anti seize on everything.
Old Dec 9, 2015 | 05:27 PM
MothAudio's Avatar
MothAudio
Michelin Premier A/S 205/50/16 [replacing OEM 195/55/16 run flats] flush on 12mm spacers. Third pix was taken before spacer install.
Attached Thumbnails OutMotoring 12mm Spacer Install Question-michelin-premier.jpg   OutMotoring 12mm Spacer Install Question-michelin-premier-rear.jpg   OutMotoring 12mm Spacer Install Question-michelin-premier-sans-spacers.jpg
Old Dec 9, 2015 | 07:59 PM
MiniRoadstah
Places tire right flush with the Wheel well edge. Nice. Take a shot of the whole side!
dhc3
Tires, Wheels, & Brakes
Nov 17, 2015 03:35 AM
InDaClubMan
Nov 14, 2015 02:53 AM
blue al
Suspension
Nov 13, 2015 10:59 PM
Jeffob5
R55 :: Clubman Talk (2008+)
Nov 11, 2015 12:38 PM
eddyjoe
Nov 10, 2015 06:53 AM
