R56 HELP! only starts then dies! 09 MCS
Old Nov 30, 2015 | 12:43 PM
Doc Pain's Avatar
Doc Pain
i mod'd my mini a lil bit by putting in a new intercooler/oil cooler / methanol injection [but ive made sure it's not runnin or even plugged in to see if it was a problem there and it wasnt..] . i have an IAC error ...i.e. car just starts then dies...poof! i also put in an oil pressure gauge [but used adptr. to keep old sensor online] a water temp gauge [a cut in onthing changed] and one of the boost adapters that u bolt on to run a boost gauge and a boost source to the methanol injection ] ----- anyone got any ideas whats going on????
Old Nov 30, 2015 | 06:15 PM
oldbrokenwind's Avatar
oldbrokenwind
Depending on the WMI system, you might have the sensors wired wrong, or it needs to be plugged in --- does it have a "fail-safe" circuit? You should be able to connect it, power it up, and test / adjust it, without running the engine, unless of course, you have a low-budget model, and / or no instructions.
Old Dec 1, 2015 | 07:16 AM
nkfry's Avatar
nkfry
You had a lot of the intake tract apart, even the smallest of air leaks on your car will cause poor idle, and stalling issues. Start with checking all your connections are clean and positive.
If you have the W/M kit piggy backed to sensors and it is either powered off or not powered at all that can cause issues if it isn't allowing the sensor value to pass through the W/M computer to the engine DME.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
haztronic
Nov 10, 2015 01:59 PM
AngeloCarrion
12
Nov 8, 2015 02:35 AM
Jim Ferrell
Nov 6, 2015 02:29 AM
