Brake pad sensor light on, pads are fine
Old Nov 30, 2015 | 09:54 AM
audiodef's Avatar
audiodef
My brake pad light came on. Around the time it did, I needed to get it through the state inspection, and it passed. The mechanic said the brakes were fine. So I'm guessing the sensor wore out before the pads. Can I reset the sensor light, or should I get a new sensor without new pads? Or should I do something else (that doesn't include replacing pads that do not need replacement)?
Old Nov 30, 2015 | 10:46 AM
Drivehard's Avatar
Drivehard
The light comes on at about 3mm pad left so as far as inspection goes its fine. But you will need pads shortly. You cant just get a new sensor on old pads as it wont fit and you cant reset as sensor triggered already. Only choice is new pads and sensor and then reset
Old Nov 30, 2015 | 10:57 AM
audiodef's Avatar
audiodef
In the back of my head, I thought that would be the case. At least I have a little bit of time to get the pads/rotors I want and DIY. Thanks!
Old Nov 30, 2015 | 11:44 AM
Capt_bj's Avatar
Capt_bj
if the light bothers you
determine which sensor is the one that tripped. Then either remove it from the pad and clip the wires ... or leave it in place and clip the wires. Strip back, tie the two ends together (a little heat shrink is a good idea to water seal) and zip tie the wires out of the way. The car sees a new sensor. For a GEN1 you need to do the reset procedure ... a GEN2 should reset itself. (PM me for the reset or search here)
You still need new pads of course and you probably want to replace the sensor at that time. But until then you don't have to see the reminder . . .
The sensor is simply a loop of wire encased in plastic, positioned properly in the pad. As the pad wears down, so does the plastic until the wire loop is encountered. When the wire breaks it creates an open circuit and the light comes on. Connect the wires works exactly as does a new sensor! A new sensor has almost a foot of leader wire b4 the connector so where you cut does not matter much.
Old Dec 1, 2015 | 02:34 PM
walk0080's Avatar
walk0080
Old Dec 7, 2015 | 08:35 AM
audiodef's Avatar
audiodef
I'm planning to do the brakes myself. Someone gave me a link to a shop he runs for a kit that includes pads and rotors for all four wheels, and two replacement sensors for under $500. I did some looking around, and for ceramic pads and parts of equal quality, I would only save $10 trying to make it "cheaper". So I think I'll get this kit.
Old Dec 7, 2015 | 11:19 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We have some great brake kits here that may interest you. Comes with everything you'll need to replace for the job. We also have a great DIY that can help you as well.
888.280.7799 | 6am - 5pm PST
daviday
Cooper (non S)
Mar 18, 2016 07:47 AM
audiodef
Tires, Wheels, & Brakes
Dec 9, 2015 07:19 PM
pauldixoninohio
Nov 14, 2015 02:44 PM
AoxoMoxoA
Nov 4, 2015 06:32 AM
AvianMan
Nov 3, 2015 11:00 AM
