R50/53 Snow wheels and tires rubbing noise metal on metal at large steering angles
Old Nov 19, 2015 | 09:37 AM
shipjumper's Avatar
shipjumper
On my '06 checkmate, I got a set of Honda steelies and some x-ice 195/60/15. Just put them on yesterday.
Today I'm getting off the highway and I hear a clunk and grinding noise on a hard turn. I pull into a lot and find a, what I thought was a piece of wire.
Turns out on hard turns the tiered ball joint threads contact the wheel. It shaved some off! I thought with the 56.1 bore and the 4x100 and same offset I was good.
I'm guessing I'm not good, luckily I have 5mm spacers at home.
Also over big bumps I'm hearing a clunking and rubbing , like shocks or something else contacting. This sound does not sound metallic.
Do I have the wrong size tire too for winter?
Old Nov 19, 2015 | 09:43 AM
Racingguy04's Avatar
Racingguy04
I don't know much about wheels but I'm running 195/55/16's on some stock mini wheels and I don't have any rubbing. The 60's will have slightly taller sidewalls but I don't think it should rub especially since they're 15 inch diameter,
Old Nov 19, 2015 | 10:11 AM
MINIAC's Avatar
MINIAC
What is the offset of the wheels?
Old Nov 19, 2015 | 10:34 AM
shipjumper's Avatar
shipjumper
I will have to pull the wheel, or look it up. I don't know off the top of my head
Old Nov 19, 2015 | 11:02 AM
shipjumper's Avatar
shipjumper
Looks like the Honda wheels are 40mm and the minis need 45mm
I'll put the spacers on asap
Old Nov 21, 2015 | 09:29 AM
shipjumper's Avatar
shipjumper
Here's the solution. I started by trying the spacers. Turns out that they are made for a different car. I tried modifying them to fit and they broke, from age, I guess.
Plan B.
I grabbed the sawzall, and trimmed the threads exposed past the nut for the tie-rod ball joint, hitting the wheel, basically making the threads flush with the nut.
Roadtest, no noise, no rubbing.
silence2-38554
Sep 14, 2017 07:44 AM
2004mc40
Dec 10, 2015 04:53 AM
Nutter
Oct 29, 2015 08:45 PM
TonyMastodon
Oct 26, 2015 03:06 PM
Khai
Oct 25, 2015 10:01 AM
