R50/53 Will r50 pistons fit r53 rods ?
Old Nov 16, 2015 | 06:03 PM
got_mini?'s Avatar
got_mini?
IM not running the supercharger in this hypothetical situation.
Just need to know if anyone knows if the pistons will fit the rods.
The crankshaft and rods seem stronger on the r53 so im thinking bout using them but with r50 pistons . . .
Old Nov 16, 2015 | 06:15 PM
got_mini?'s Avatar
got_mini?
Just found out the small end is differnet sizes so thats a big no.
Old Nov 17, 2015 | 08:18 AM
Saltysalt's Avatar
Saltysalt
makes sense since the boost would require a stronger pin for the piston. but if you had r53 pistons, should be all set, or when ordering new pistons, you could just request forged pistons with that pin size
Old Nov 17, 2015 | 02:00 PM
nkfry's Avatar
nkfry
In this hypothetical question will you be running boost of any form? Turbo/supercharger.
If you stay NA you will need to make sure to order or use proper pistons to keep your compression ratio of 10:1, R53 pistons will change your ratio to 8.5:1.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
MazMini
105
Apr 16, 2016 07:59 PM
Mrniksmif
Feb 3, 2016 07:33 AM
JontXu
Nov 16, 2015 08:51 PM
Tslatt
Nov 3, 2015 09:09 AM
audio131
Oct 30, 2015 09:28 AM
