R56 spark plug shananigins
Old Nov 11, 2015 | 09:22 AM
2nsane's Avatar
2nsane
So my 2010 MCS just hit 50k so I decided to swap out the plugs for piece of mind. All 4 plugs had the ground strap connected to the electrode by a thin strip of carbon, with a heavy breath it blew off the plug. I've never seen this before. Any ideas?
Attached Thumbnails spark plug shananigins-20151111_115143.jpg   spark plug shananigins-20151111_115514.jpg
Old Nov 11, 2015 | 10:51 AM
Not on the tips like that. When I pulled mine out there were dirty but did not have a thin carbon build up above the electrode. Have you had your MINI carbon blasted on the intake ? Wonder if its access build up ?
https://www.northamericanmotoring.co...-cleaning.html
Old Nov 11, 2015 | 08:49 PM
renchjeep's Avatar
renchjeep
The plugs are recessed into a deep well, I believe. I change plugs on Ford cars and trucks all the time, and the plugs sit deep into the head. Yes, I have changed the plugs on my MINI, and I did the same as Ford recommends....remove coil, then using compressed air, blow any debris from recessed spark plug holes before removing spark plug. Maybe you didn't blow the debris out of the hole before removing the plug, and it picked up some debris on the way out? I have not looked at my Bentley manual to see if it advises the same procedure, but I would assume that it would include that info. Just an idea.
Old Nov 13, 2015 | 09:33 AM
2nsane's Avatar
2nsane
No the sp holes were actually emaculate. I was impressed how clean the plug holes were. The car has never had the valves cleaned with walnut blasting. Local dealer wants $600. looks like I will have to see if anyone local to the charleston area can assist.
Old Nov 13, 2015 | 09:52 AM
That DIY is linked above, I would at least have them checked for carbon build up.
Beezel
Jan 23, 2016 09:50 AM
WayMotorWorks
Dec 9, 2015 08:11 PM
2010CHILI
Nov 15, 2015 05:36 AM
bikerbob951
Nov 11, 2015 08:33 AM
Niccolo_Machiavelli
Navigation/Audio
Nov 8, 2015 03:43 PM
