Michellin Premier A/S
Old Nov 10, 2015 | 04:44 AM
dhc3's Avatar
dhc3
I am looking for a set of tires for my 2012 MCS.
I have had run-flats in the past; didn;t like the harsh ride. So I would like a set of non RFTs that have good handling but I prefer comfortable ride over top performance. Good tread wear is important as well. And good snow performance as this car will be driven through Chicago winters.
The Michelin Premier A/S seems to fit the bill. Anyone with experience using this tire? Or suggest alternative choices? Thanks!
Old Nov 10, 2015 | 07:06 AM
2010CHILI's Avatar
2010CHILI
I love my A/S3's
Old Nov 10, 2015 | 06:07 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Premier A/S should be fine for your needs. Worth the expense, Check for special discount offers.
If you have stock suspension you can use 215/45-17 on OEM 17" rims (this gives more choices)
http://www.tirerack.com/tires/survey...earDiameter=17
Old Nov 12, 2015 | 10:47 AM
Alex@tirerack's Avatar
Alex@tirerack
If your willing to give up a bit of ride quality and road noise for snow traction, you can consider Pirelli Cinturato P7 all season Plus
Old Nov 12, 2015 | 10:52 AM
Alex@tirerack
I have a Premier series tire on my car now. They are fabulous so far, only 6k on them so far. Waiting to see how they fair in winter, before I switch to my Blizzaks.
Old Nov 13, 2015 | 04:12 AM
dhc3's Avatar
dhc3
So just to understand you correctly. With stock suspension I can bolt on 17's? So maybe use 16s for winter tires and 17 for summer?
Old Nov 13, 2015 | 04:17 AM
dhc3's Avatar
dhc3
Would be interested to hear that, as I thought the Premier would make a good tire for winter as well. Obviously not a Blizzak, but an acceptable winter performance for an all season tire.
Old Nov 13, 2015 | 07:41 AM
hsautocrosser's Avatar
hsautocrosser
You bet. 16x6.5 and 17x7 were the factory options.
If you don't have an owner's manual you can download a PDF version for free at MINIUSA.com.
Old Nov 16, 2015 | 08:26 AM
cptplt's Avatar
cptplt
If you dont want RF get the Nokian WRG3. I live in Elgin, running these for over a decade on various Subarus and minivans. Last 50K, has winter rated traction , as good as any performance winter tire I've had and better than any factory all season in summer I've had. And no need to change tires every season.
There is a RF version WR D3, I actually asked probably the biggest Nokian dealer in Chicagoland- Suburban- about getting some for my justa Mini. There are none in stock in the US and no idea when available!!
Old Nov 17, 2015 | 03:35 AM
dhc3's Avatar
dhc3
Interesting alternative; I will look into that . Thanks!
silence2-38554
Sep 14, 2017 07:44 AM
tylewis
Feb 10, 2016 05:13 PM
rphox2003
Oct 19, 2015 08:59 AM
jfolkson
Oct 17, 2015 11:32 AM
Kahnfucious
Oct 13, 2015 01:00 PM
