R56 R56 stutter solved!
Old Nov 7, 2015 | 03:56 PM
nutsofamily's Avatar
nutsofamily
R56 stutter solved!
1 month of stutter under load at times. Seafoamed with no change. Hooked up wifi obd2 and registered cylinder 2 misfire.
Changed 1 coil purchased from Napa and HappyDays again!
Old Nov 8, 2015 | 11:05 PM
MNMLST's Avatar
MNMLST
Nice!
I'm about to change one of mine, too. Did you go with stock of aftermarket?
Old Nov 9, 2015 | 01:12 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Glad that was all that was needed to resolve your misfire!
@MSMLST Typically, I'd stick with Genuine or the OEM supplier coils. Here if needed.
888.280.7799 | 6am - 5pm PST
Old Nov 9, 2015 | 09:17 PM
nutsofamily
coil
Originally Posted by MNMLST
Nice!
Napa sold me a bosche for 70.00
Old Dec 30, 2015 | 06:05 PM
S_Banks's Avatar
S_Banks
Have to ask, which (wifi obd2) did you end up getting and where from? Appreciate any feedback...
Old Dec 30, 2015 | 06:15 PM
nutsofamily
Obd wifi
I used a napa one for 35 and works great.
I believe it was from eBay several years ago
Old Dec 30, 2015 | 09:21 PM
S_Banks's Avatar
S_Banks
Thank you so much "Nutsofamily" very much appreciated!
Old Jan 5, 2016 | 06:49 PM
S_Banks's Avatar
S_Banks
Stupid question time... while I'm experiencing these "coil" symptoms, stuttering, stuttering during rain, no determinable rhyme or reason when it happens. I'm don't get an "Check Engine" light on my dash. So of course when I hook up an OBD2... it has nothing to report. So my question is, hooked up the OBD2 and used OBD Auto Doctor to read the data. Under "Misfire" category there is a green check mark, which tells me everything is fine.
What am I missing here? No check engine light and no misfire reading. Plan to take out the spark plugs this weekend to get a visual on the burn and gaps.
Thanks,
Old Jan 5, 2016 | 06:55 PM
thebombardier's Avatar
thebombardier
I have no clue what conditions actually set off the CEL, because I had a misfire issue after tuning and it took about 2 days of the misfire getting worse (I was troubleshooting spark plugs and stuff and coils were the last thing I wanted to do) before I misfired constantly for about 2 seconds (sounded like a muffled machine gun) and I got a CEL and it went into limp mode.
Old Jan 5, 2016 | 07:07 PM
nutsofamily
Thanks,
I never got a check engine light until it was bad. I kept my obd2 hooked up and drive up a steep hill in 5 the gear to bog it down. That's when I got a great deal of stutter and error code.
Old Jan 6, 2016 | 06:34 PM
S_Banks's Avatar
S_Banks
Thank you... looks like I'll try the 5th "bog down" this weekend prior to physically checking the plugs. I'll report back when I get everything settled. You folks are awesome, Thank You!
Old Jan 6, 2016 | 07:45 PM
GAT's Avatar
GAT
Thanks,
Check out my posts here:https://www.northamericanmotoring.com/forums/r56-hatch-talk-2007/297555-r56s-sounds-like-its-going-to-stall.html
Old Jan 8, 2016 | 06:28 PM
S_Banks's Avatar
S_Banks
Thank you GAT, it's appreciated!
OK, let me bring everyone up-to-date;
Car:
2009 Mini Cooper (Non-S)
Mileage: 74,080 (bought CPO w/33k on it) serviced by MINI up until my ext/war ran out a few months ago.
Equipment:
BAFX Products 34t5 Bluetooth OBDII Scan Tool for Android Devices
OBD Doctor App - Running on a Nokia Lumia 929 (Icon) Windows 10 - (nice feature, it allows me to email myself the data. Pretty handy.) I believe the reason why I didn't get any "codes" on my initial run was, I didn't know I had to manually turn on the specific "sensors" in the app that I wanted/needed monitored. User error!
Symptoms:
Hesitation/stuttering at no discernable time, engine temp, or mileage
So after learning a bit more about the app, I got TWO "Pending" codes on my 25-mile drive home tonight.
On one app/drive cycle: P0015: "B" Camshaft Position - Timing Over-Retarded (Bank 1) (Powertrain, Generic)
On second app/drive cycle: P0301: Cylinder 1 Misfire Detected (Powertrain, Generic)
CYCLE meaning during the one trip, the app was turned off and back on.
So, where do I go from here, what should be my next step? Remove the plugs to try to detect any noticeable difference in the plug on Cyl-1 and proceed from there e.g., buy an ignition coil or... ?
Old Jan 8, 2016 | 06:36 PM
thebombardier
No sooner do I comment in this thread I blew a spark plug and I'm misfiring. Here's a PSA, don't ever buy Autozone's Autolite spark plugs. I put it in (didn't fit in my specialty socket either) and the threads were slightly too small and it actually didn't tighten like the NGKs do. Plugged in the coil pack, started up and the plug blew out of the threads. Luckily I didn't damage the engine any.
Only buy NGKs or OEM people.
Old Jan 16, 2016 | 12:07 PM
S_Banks's Avatar
S_Banks
Well, $22 for an OBD2 Bluetooth device, $10 for an OBD App, $28 for a Bosch Ignition Coil... $58 bucks (total) later and I should have the issue solved. Will monitor the car this week for symptoms and report back. But it made me think of how much money this forum has saved people over the years, makes you curious doesn't it?
Old Jan 16, 2016 | 12:35 PM
GAT's Avatar
GAT
Where can you get a Bosch ignition coil for $28? Not trying to be funny but I've never seen them priced that low?
Old Jan 16, 2016 | 12:56 PM
S_Banks's Avatar
S_Banks
Obtained through Amazon.com - BMA Auto Parts (Importers & Distributers) out of Glendale, CA in business since 1978. Genuine Bosch, and the computer etched OEM data on the ignition coil is an exact duplicate to what I replaced.
Old Jan 16, 2016 | 01:02 PM
GAT's Avatar
GAT
Thx bud, appreciate it. I need to purchase 2 as well
Old Jan 16, 2016 | 02:51 PM
S_Banks's Avatar
S_Banks
BTW... if you don't know, you can sign into Amazon using "Smile.Amazon.com" and have a portion go to your favorite charity of your choosing (from a list), so everything that qualifies for that program that I purchase... a portion goes to "Wounded Warrior Project" my charity of choice.
Old Jan 16, 2016 | 03:08 PM
GAT's Avatar
GAT
Awesome, will do
wheeldusty
Apr 28, 2016 09:11 AM
Jim Ferrell
Mar 28, 2016 08:46 AM
Jim Ferrell
Nov 4, 2015 11:31 AM
W-SMini
Oct 22, 2015 02:30 PM
Jim Ferrell
Oct 10, 2015 09:42 PM
