R56 HPFP again...I think
Old Nov 3, 2015 | 08:00 PM
renchjeep's Avatar
renchjeep
Had it replaced under remaining factory warranty Jan this year at 34k. Now at 49k, same symptoms as before, same misfire codes, same reduced power. Factory warranty now over due to time. Have an aftermarket Hendricks warranty. Taking my JB+ off and making appointment at dealer. Hope they warranty it again. Does anyone think the dealer will freak out about my ALTA hot side turbo tube and my bigger intercooler? Sure dont wanna have to remove those 2 mods....
Thanks in advance--Chris
Old Nov 4, 2015 | 08:30 PM
renchjeep's Avatar
renchjeep
Friday 7:40 a.m. appt at MINI of Escondido. SA said most likely will be covered under emissions warranty or my aftermarket Hendricks warranty. They are providing me a loaner car. I will update when the diagnosis is made. When the first HPFP failed, I got a fuel pressure code in addition to the misfire codes. Maybe just coil pack(s)? I replaced plugs with NGK Iridiums at about 36k, so the plugs should be fine, I would think.
Car runs fine if I stay off of the loud pedal a bit. 2/3 to 3/4 throttle is when she starts to miss and buck. REALLY hard to drive without getting into the turbo!
Old Nov 9, 2015 | 06:04 AM
roadrunner255's Avatar
roadrunner255
Having the same issue with my GP2, plugs were fowled with carbon. Taking it into the dealer Thursday.
Didn't find any codes on my generic scanner, we'll see.
Cheers!
Old Nov 9, 2015 | 11:54 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
What did they say was the diagnosis? For anyone wanting to test to see if it is the HPFP, we have some info that can help with that in this article here.
888.280.7799 | 6am - 5pm PST
Old Nov 9, 2015 | 04:20 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Check your warranty booklet, look at the US & CA emissions info. HPFP could be covered as an emissions component. 7 or 8 years. 49K miles is under threshold as I recall.
Old Nov 9, 2015 | 06:43 PM
renchjeep's Avatar
renchjeep
No diagnosis yet. Well, at least I haven't heard from the dealer yet. If it is the HPFP, it was just replaced in Feb of this year, maybe 13k ago. I would hope that they would warranty that, being so new.
Old Nov 11, 2015 | 10:03 PM
renchjeep's Avatar
renchjeep
SA called me today. Said he had contacted warranty company, seeking replacement of all 4 coils, as my plugs were fine, HPFP was doing as it should, no other faults found. I would think that misfires would be covered under emissions warranty? Nope. SA is also seeking trans input shaft seal leak (which I never saw), including a "sleeve" (I know what that is, it's to cover up the damage done to the actual shaft, not happy about that!) to be covered, as well as possible accesory belt tensioner replacement, maybe aux water pump as well. I asked SA if the warranty company would also cover the clutch (which has been fine) if found to be contaminated with oil from the leaky seal. SA said nope, only covers the seal. WTF? My clutch feels fine right now, but if the leaking seal has fooked up my clutch, I am on the hook for replacing the clutch? Yup. So, while it's out, I told him that I wanna see the clutch disc, then make my decision. I am hard on my MINI, but at 50k, and knowing how I use my clutch (gently) probably have another 50k plus left...IF the leak has not fooked up my clutch material. I LOVE the way these warranty companies "spin" stuff! I could be on the hook for a clutch because a "covered" seal took it out? Geez. And WTF. And "sleeving?" I love my MINI, but....now starting to see the issues that crop up after a few miles. I usually get 200k plus from my rides. I was hoping for the same or more from my MINI. Waiting....
Old Nov 12, 2015 | 07:24 AM
Sometimes those aftermarket warranty companies have small print on clutches, wear and tear ...etc They will try to get out of everything if you make a claim. You have to push them, been there before.
Were the coils rusted on the sleeves or water seeps down past the seal ? Pic of coils.
The HPFP been noted here:
https://www.northamericanmotoring.co...r-r56-jcw.html
Old Nov 12, 2015 | 07:15 PM
renchjeep's Avatar
renchjeep
SA called today. Warranty rep looked at car, said they would cover 4 coils, belt tensioner, and water pump pulley (I think). Will not cover trans input shaft seal leak, as it is only seeping and not dripping. Said to call back when it IS leaking, and they will cover it. Not a clutch, though. Oh well. Hope it never starts dripping, right? Also, I found it odd that the coil packs were NOT covered under MINI emissions warranty. I would think they should be, but what do I know? Parts on order. Maybe I can get it back tomorrow or Saturday. Maybe not til Monday.
Old Nov 18, 2015 | 09:50 PM
renchjeep's Avatar
renchjeep
Update
I know, it's been a while. Believe me, I know! The 2015 Cooper loaner is OK, the 3 cyl turbo engine pulls pretty well, but the auto trans? Not a fan of that slushbox. Anyway....hoping to get my MINI back tomorrow. SA said the warranty company agreed to all 4 coils, the acc belt tensioner, the water pump pulley, AND the aux water pump for the noise. First aux water pump they got was not talking to the ECM, may have been damaged during install. ? This will be the third aux water pump, not counting the one that they just got which did not function properly. They were planning to get it all put back together today, do extensive test drives, then try a cold start tomorrow morning. Sorry for the saga. But, I will post up once I get her back, and let everyone know what was covered, the final results, and how much it ends up costing me. Supposedly only a $50.00 deductible with my extended Hendricks warranty. If I hand them 50 bucks and drive away with a happy MINI, I will be impressed. We shall see....
Old Nov 19, 2015 | 05:53 PM
renchjeep's Avatar
renchjeep
Just got home with my MINI. Total cost? $48.33! Runs flawlessly now. Now, to let it go to sleep, disco the battery, and re-install my JB+. I can REALLY feel that it is off!
ECSTuning...coils show no signs of moisture or rust. All 4 were replaced. I have the old parts, but no way of knowing which 2 were failing, as the tech didn't mark them.
Old Nov 20, 2015 | 05:45 AM
Thanks for the update, glad it was just those coils. Now back to some motoring.
Shane Wendel
R60/R61 Stock Problems/Issues
Nov 11, 2015 01:14 PM
Oct 28, 2015 10:47 AM
1R53
Oct 26, 2015 05:54 AM
StPeteMiniS
Oct 21, 2015 09:03 AM
Vader-S-All4
Oct 13, 2015 06:26 AM
