R56 Disconnecting the battery
Old Nov 1, 2015 | 02:13 PM
Sassenach's Avatar
Sassenach
I intend to disconnect the battery in my 2012 JCW to replace the steering wheel.
Have been reading about problems when replacing the battery. Battery needs registered and set by a Mini dealer to correct electronic problems.
Looking for confirmation that this is not required when just disconnecting and not replacing the battery.
Thanks for any feedback
Old Nov 1, 2015 | 02:15 PM
timski's Avatar
timski
Well I replaced mine with an optima red top and no issues. But some say it needs to be registered to charge it properly and so the car knows that the capacity changed etc. 2011 JCW
Old Nov 1, 2015 | 02:31 PM
oldbrokenwind's Avatar
oldbrokenwind
A basic disconnect - maintenance - reconnect does not require or even need registration. Only one terminal needs to be disconnected, preferably the negative / ground terminal.
Old Nov 1, 2015 | 02:42 PM
rkw's Avatar
rkw
That's correct. Registration is only when replacing the battery.
Old Nov 1, 2015 | 04:33 PM
Sassenach's Avatar
Sassenach
Thanks all
Old Nov 2, 2015 | 12:32 PM
coachvminis's Avatar
coachvminis
So your saying another light will come on if I disconnect both terminals?
Or no?
I disconnected both to reset the check engine light and air bag light after doing a few things and both lights still on and battery is fine with no battery light...
So the ECU is reading the Battery Power? or life? or will have a headache if changed to a Sears top o the line battery? Yeah! Another reset...just gets better everytime..
Old Nov 2, 2015 | 02:07 PM
oldbrokenwind
Or no?
Disconnecting both terminals will NOT cause a CEL when reconnected properly. You will have to reset the clock and any preset radio stations, and maybe check the window auto up / down and sun roof open / close settings, but that's it.
The ECU monitors and records how much battery charging is done. When the battery is replaced, the ECU will "overcharge" it, unless it is "registered". There are those that have replaced their battery without getting it registered, and they say no problems were caused. I chose to not take that chance when replacing mine --- I let my local dealer do the registration process --- took about an hour. Other threads reference using a variety of batteries. I know of no reason why the Sears version for your Mini wouldn't work. Possibly the dealer won't register a non-OEM battery?
Disconnecting the battery is one method to reset the "learning" function --- it will erase all your learned "driving habits", and clear any CEL's you may have. It will not fix defects that cause a CEL, so if the defect has not been fixed, you get the same CEL again.
Old Nov 2, 2015 | 02:26 PM
SODA66's Avatar
SODA66
I had no problems when I switched my steering wheel and disconnected the battery. In fact i took the seats out for a week and had the car sit with the cables disconnected and no issues when I hooked them up.
2011 Clubman
Old Nov 3, 2015 | 11:26 AM
Its the IBS system when you see a cable with a module on it.
https://www.northamericanmotoring.co...-registry.html
Old Apr 23, 2020 | 06:40 PM
HungHung's Avatar
HungHung
Wait 15 minutes before disconnecting the battery
I was reading some post and comments and one person suggested waiting 15 minutes before disconnecting the battery so there FRM3 can go to sleep, I guess like a computer. I didn't do this before working on my r55 and now I got traction light and airbag light warning. I can't confirm this but waiting 15 minutes is better than diagnosing. Im not liking mini Cooper bmw electrical/computer/software engineering.
midnightblackjcw
Nov 8, 2015 06:06 AM
daonlyillwiz
Oct 16, 2015 09:36 PM
dropnstylez
Oct 15, 2015 08:04 PM
3gswish
Oct 4, 2015 06:01 PM
Jim Ferrell
Oct 4, 2015 04:53 PM
