R56 Blow off valve?
Old Oct 21, 2015 | 09:02 AM
BadgeFTW's Avatar
BadgeFTW
From: Greenville, SC in the United States of Awsome
Blow off valve?
I have a R56 and no upgrades(for all i know) but when i accelarate up to boost and let off i hear a faint woosh like a blow off valve. Where is the blow off valve? How can i tell if my MINI has an aftermarket valve? Do R56 MINIS come stock with blow off valves?
Old Oct 21, 2015 | 09:10 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
You have a diverter valve. I would check it to make sure that it's in good condition as it's common to see them fail at the diaphragm. Here is a good NAM thread with images and a video. It's #2 below, HERE to see an image of what it looks like. If you want, I would recommend the Forge DV as a good alternative upgrade if yours has failed.
888.280.7799 | 6am - 5pm PST
Old Oct 21, 2015 | 09:12 AM
BadgeFTW's Avatar
BadgeFTW
what does a diverter valve do?
Old Oct 21, 2015 | 09:19 AM
PelicanParts.com
Vendor
The diverter valve is a pressure release system that "diverts" the unused pressure back into the system. It helps to prevent compressor surge.
Old Oct 21, 2015 | 10:00 AM
BadgeFTW's Avatar
BadgeFTW
thanks for the help bro
Old Oct 21, 2015 | 10:01 AM
PelicanParts.com
Vendor
My pleasure!
Old Oct 21, 2015 | 10:43 AM
sub3622's Avatar
sub3622
Pelican, if the diverter valve is bad I would supposed to see a CEL? Right?
Old Oct 21, 2015 | 10:50 AM
PelicanParts.com
Vendor
No, it could have an issue without a CEL. I've had a bad DV (on BMW) with no CEL. You can actually hear them when they go bad. It sounded like a hissing or wooshing sound on deceleration and acceleration, but not as pronounced. It's a noise like air is escaping somewhere. I posted a link above to a thread where an individual posted a video to the noise they heard.
Old Oct 21, 2015 | 11:22 AM
sub3622's Avatar
sub3622
I hear that small whoosh sound when i take my foot off the pedal, i thought it was the intake system because i recently (three months ago) changed my stock cooper s air intake box system to a jcw tunning kit air intake box system (with oem cone filter) but i did not hear that woosh until a few days ago so i wonder if my diverter valve is bad too.
Old Dec 1, 2015 | 10:45 AM
Ali_C_911's Avatar
Ali_C_911
To make sure I'm reading this right... Are you guys saying that normally the swoosh sound shouldn't be there that happens when you take your foot off the accelerator?
I bought a 2010 s about a month ago with 36k miles and it makes the swoosh sound. Actually I like that sound but I came across this thread searching for cel issues as the cel light came on earlier today.
Old Dec 1, 2015 | 11:00 AM
PelicanParts.com
Vendor
What code is being thrown for the CEL?
Old Dec 1, 2015 | 12:32 PM
sub3622's Avatar
sub3622
The whooshh sounds only when i take my foot off the accelerator.
Old Dec 1, 2015 | 04:21 PM
Ali_C_911's Avatar
Ali_C_911
This is what I see in the "Check" menu. Is this the kind without a code or is there somewhere else I need to check to see the codes?
Old Dec 1, 2015 | 04:22 PM
Ali_C_911's Avatar
Ali_C_911
Yes same here. Honestly I like that sound at times.
Old Dec 2, 2015 | 08:32 AM
PelicanParts.com
Vendor
You need to get or borrow a diagnostic scan tool that plugs into your OBDII. That is the way you'll be able to read a code. You could try going to a local auto parts store as sometimes their equipment is able to read codes for you.
Old Dec 2, 2015 | 12:36 PM
sub3622's Avatar
sub3622
I like the sound of whooshhh but i do not have an open air intake filter so it should not make that noise, right? even if i have a cone paper filter inside of the factory air box.
Old Dec 3, 2015 | 08:20 AM
Sassenach's Avatar
Sassenach
You guys have me thinking. I can hear an (air pressure) type hiss when i have the window down and change gear under brisk acceleration. I like the sound as it sounds like a very tame blow off valve. I thought it was normal as it is pretty muffled.
Are you saying it is the sign of a bad diverter valve? Should there be no noise? For the record my 2012 JCW is stock in the engine department.
honderpilot
Oct 10, 2015 07:56 PM
newowner
Sep 15, 2015 07:18 AM
Sep 10, 2015 03:36 PM
Tires, Wheels & Brakes
Sep 10, 2015 02:53 PM
Sep 8, 2015 11:37 AM
