R50/53 Vibration upon Acceleration..Worn CV housing??
Old Oct 16, 2015 | 06:26 PM
SooperCoopers's Avatar
SooperCoopers
Hello!
I am currently experiencing vibration upon acceleration in my 03 R53. It can be felt in the 20mph range and is much more intense when accelerating in the 50mph+ range.
I went to take a look a my drivers side CV joint...and this is what I discovered. I noticed wear inside of the CV housing (looks like some of the grease escaped the boot over time.) I can physically feel a slight indentation where I (assume) the bearing was metal-on-metal with the housing at some point. Note that one of the signs of wear is slightly more brown than the rest...this is the deepest groove. I believe the color change is from high heat.
Could this wear be the sign of my vibration when I accelerate? Has anyone seen this before? Regardless, I think I will replace this piece... I am guessing it just pops out from the transmission with a screwdriver?
Old Oct 18, 2015 | 07:36 AM
gpwpat's Avatar
gpwpat
I have this same problem. I have had it before. I put in cheap axles and only got 80k miles. This time I am torn between driveshaft shop or rebuilt.
pocketmaster
14
Dec 21, 2019 02:12 PM
David.R53
Oct 12, 2015 10:13 AM
Alpha Motoring
Oct 11, 2015 09:45 AM
bshane
Oct 10, 2015 09:35 PM
got_mini?
Oct 5, 2015 12:10 PM
