Suspension Shreaded H-sport arm bushing
The Verdict.
Thill has 15 turns, 11 of which are left-handers. After just two track days, the right rear, outer side bushing in the lower H-sport adjustable arm failed. Heck, I wasn't even able to finish the second day! I do drive it hard, but what's up with that?
Do I really need to use urethane bushings? If so, that kinda sucks.
Does anyone make better bushings to fit those arms? Seems to me the stock H-sport bushings are garbage. Might be ok for play time, but not when pushing the car 95% or more.
By the way, the first symptom showed up when the car acted like it wanted to step out while pushing hard into left hand turns, but it held the line ok, probably because I'd just stomp on the gas pedal. LOL
Phil
Phil
Thanks for the post Monkey. I have been planning H-sport upgrades myself. Maybe there is something better. Have you done Thill opposite (clockwise) direction? I am thinking of going Sept. 24th.
Andy
Andy
Andy, I have not done Thill backwards, but I want to. We've been trying to get a motorcycle day run backwards for some time, and one organizer just did it recently and riders loved it.
I don't think there is anything wrong with the H-sport bars, just the bushings don't seem to hold up well, or maybe it's a fluke? The bars themselves are beefy as hell, I like 'em.
The 24th is NCRC, eh? I'm a member (#997) and plan to be there, too. We should hook up...
Phil
Phil
Monkeyboy,
How long have you had your H-sports? Maybe contact H-sport and ask for the bushings to be replaced or go with urethane. Could be a defective bushing, then you won't need to replace them with urethane.
Phil
Andy
You mean the competition rear camber links?
DANG! I just ordered a set!!
What was your camber settings?
did you have both upper and lower links?
thinking now I should of gone with the heim joints!
see below: Thilll turn 11, I/m currently running with NASA folks.
Andy
Monkey Boy,
Have you talked to H-Sport yet about the bushing failure?
This is the second such failure I've heard of.
Although I've ordered a set of control links, I don' t think I'll install them just yet. I have a track day at Infineon on 8/22 and 9/11. A failure like yours at turn 10 would likely send you into the concrete wall.
I'm trying to get a hold of the person I ordered them from but all I'm getting is "Sorry, that mail box is full..."
Asodestrom,
Yea, I'd like to join NCRC. I'll join and come out and play!
I track with another friend who has a MCS at NASA events - lots of fun, action and learning.
Asodestrom,
Originally Posted by Bisch
There was a post a few weeks ago about a bushing failure...If I'm not mistaken the mfg's reply was something like "they are meant for street driving?"
Hey, just installed the H Sport lower control arms and springs... Haven't had any problems... yet.... What is the recommended lubriction for the bushings and how often... What about the sway bar bushings too...
18k miles on my H-Sport control arms, including several Dragon, Auto-x and Track events, with no bushing problems. Perhaps your bushings are an isolated event, or you did not lubricate them correctly.
Originally Posted by sanddan
Monkey-Boy,
Did you lube the bushings and if yes with what brand/type lube?
One of my concerns is how thin the bushings are. I suppose they're fine for street, but it sure didn't take long to split off one half with track duty.
The bushings were lubed properly.
Bushing lubricant
I just received my H-Sport rear sway bar and it did not have any lubricant with it. Does anyone know what to use, or should I just wait for them to ship the orig package next week?
Since you probably want to go for a spin, and not wait until next week, I'd go pick-up some lithium grease for a couple bucks. The stuff they'll send to you is really sticky! With the zerk fittings, and if you have a grease gun, lithium is a great way to go for re-lubes as well...
Good luck!
Good luck!
Just to be clear. I don't know for sure what lube was used on the arms. I do know we used the lube included with the h-sport sway bars for that install, but I do not recall if the bars came with lube. Sorry if I mislead anyone. I can tell you the bushings had plenty of lube.
and a quote from the h-sport web site about these arms, as an FYI. I would expect the bushings to hold up based on this statement, wouldn't you?
I have a call into them.
The Sport Rear Camber Links are designed and tested to suit any street or track environment.
Interesting news on this story.
Hsport responded very professionally to my problem, and I was told there was a revision to the design on the bar ends, and a different bushing. My task is to see if I have the new or older version (I suspect I have the older one by their description.) And they're supplying new bushings in the meantime.
Those who bought the arms and are worried about using them, I encourage you to contact Hsport and discuss your concerns. I'm under the impression that they care very much to deliver a fine product and are willing to support us and our concerns.
I'll let you know where this ends up.
Phil
Phil
Okay.....
I checked my control arms today which I installed one and a half weeks ago and the driver side lower bushing split apart......the car was never driven on the track or in an auto-x. Everything was greased up.
I talked to Randy who I bought the arms from. He was just back in the shop after some health problems and he will talk to H-Sport. Most likely there is a batch of bad bushings out there since he has his installed for over two years without anyh problems. I will have mine replaced by arms with heim joints. After driving just on the highway and those failling already I do not trust those rubber bushings anymore.
Alex
Alex
