R56 buzzing sound under turbo after shut off 2008 MCS
Old Oct 2, 2015 | 09:54 PM
tacticalbacon02's Avatar
tacticalbacon02
i have a 2008 MCS that every time i shut the car off i hear a buzzing from up front that sounds like it coming from the turbo or vacuum pump area... is this the turbo coolant pump i keep hearing about thats supposed to keep circulating fluid around the turbo after shutdown?
Old Oct 3, 2015 | 05:33 AM
cerenkov's Avatar
cerenkov
Yes. It is the aux pump.
Old Oct 5, 2015 | 05:05 AM
coachvminis's Avatar
coachvminis
I have the same Buzz..weird...So where is this Aux pump located?
Old Oct 5, 2015 | 06:45 AM
cerenkov's Avatar
cerenkov
I would not say that it's weird. If the temperature is above the set point then the aux pump will run.
Item number 2 in the diagram:
http://www.realoem.com/bmw/images/diag_4jto.jpg
Old Oct 5, 2015 | 10:54 AM
TheBigNewt's Avatar
TheBigNewt
Mine does that almost every time I turn off the engine, sounds sorta like a fan, for about 30-60 seconds. Maybe it is a fan, but I hear it easily. My 2007 did it too.
point665
Sep 29, 2015 12:41 PM
Miniwaukee
Sep 29, 2015 09:22 AM
jennster
Sep 28, 2015 06:19 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
