07 mini cooper n12 cel on
Old Oct 1, 2015 | 09:54 PM
Matthew Lobb's Avatar
Matthew Lobb
Hi I've got a 07 mini cooper non turbo with the Cel on code p0014 - ex cam pos advanced. I've tried replace the vanos solenoid and even swap side to side same code keeps returni
ng. I've removed the valve cover and noticed quite a lot of varnish and sludge. Wondering if this has anything to do with the problem. No rattle noises evident.
Old Oct 7, 2015 | 12:30 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
P0014 - 'B' Camshaft Position Timing Over-Advanced or System Performance (Bank 1) and some more good info here.
Ran across this thread here and here. Most of what I found was the VANOS and cam position sensors. More solved with VANOS cleaning than the cam sensor replacement, but the last thread I posted ended up being timing chain skipping. Hope some of this helps you a little while you chase down the issue. Good luck.
888.280.7799 | 6am - 5pm PST
bobbiemartin
Jan 20, 2016 05:28 PM
Philip Wong
Sep 28, 2015 05:51 PM
mini pooper
RSR Motorsports Coverage
Aug 13, 2015 12:10 PM
Aug 11, 2015 09:01 AM
eliseo1981
Aug 6, 2015 05:00 AM
