R50/53 Buying a 02 Justo 117k ... Need Advise
Old Oct 1, 2015 | 08:20 PM
MazMini's Avatar
MazMini
So I found a little mini that I like that needs a little help. It has been maintained and is a sound car but its needs the following parts listed below.. the good is that Im buying it for $2500.00 and it was checked out at Mini two weeks ago (called to verify sellers comments).. Been doing some reading all night on it and it looks like something I might do...
2002 Mini Base 1.6L Justo
Needs:
- Cooling Fan (70.00 from Rock Auto)
- Headliner (dunno?)
- Glove Box Latch (Saw a fix on Youtube)
- Tensioner Pulley is making noise (looks like a easy swap)
- Rotors (Easy enough)
- Cracked Windshield (Might cost a little to replace)
- rear tail light ($65.00 on Ebay for a set)
- Oil Pressure light comes on when sitting idle but I noticed it could just need the spring that builds pressure when sitting idle... (also found out he services the car at Tire Kingdom where they might have thrown the spring away)
- Will need a clutch next year (for my sanity)
- Also has a P113c code (have to look that up) Some say its an O2 sensor which is an easy fix..
Overall everything else works just fine and I think it would be a great daily car and beater car for the winter...
Thoughts??
Old Oct 1, 2015 | 10:22 PM
FatherG's Avatar
FatherG
So if you are comfortable with all the known issues, it seems like a fair price. How is the suspension? I just did the headliner - not too difficult. I have an '02 R50 that is my daily driver.
Old Oct 1, 2015 | 11:00 PM
MazMini's Avatar
MazMini
Suspension is surprising well and stiff.. My thoughts exactly.. I can get some cloth from EBay and knock it out ..
Old Oct 2, 2015 | 06:18 AM
Khai's Avatar
Khai
Needs:
Thoughts??
For the oil pressure light at idle: replace the oil filter with oem. My first oil change In my '02 resulted in this problem. Inexpensive fix but costed me a lot of sanity to figure out they put an oil filter in that was completely different (didn't even snap in place).
Old Oct 2, 2015 | 07:27 AM
FatherG's Avatar
FatherG
https://www.northamericanmotoring.co...liner-r50.html
My headliner job.
Old Oct 2, 2015 | 10:18 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Are you using a generic code reader? I believe O2 codes range from P1132 - P1139 and the code you're getting is more generic. Good info in this NAM thread HERE with a link in the 2nd post to another good thread. OP said bank 1 11-78-0-872-674 was the sensor it was pointing to. If you need any help with the repairs be sure to check out our tech articles here. Good luck!
888.280.7799 | 6am - 5pm PST
Old Oct 2, 2015 | 10:21 AM
MazMini's Avatar
MazMini
Thanks! I will be probably doing some ordering from you here in the next week..
Old Oct 2, 2015 | 10:24 AM
PelicanParts.com
Vendor
You're welcome. If you need anything else or have any questions please do not hesitate to reach out to me. While you order, if you add any of these brands here to your cart be sure to use the promo code COOPER at check out to save 10%. Offer is good until October 6th.
eliseo1981
Jan 28, 2021 02:45 PM
flyers47
Jul 27, 2020 02:38 PM
messyjesse96
Aug 12, 2015 05:51 AM
Aug 11, 2015 09:01 AM
atenzany62
Aug 9, 2015 05:54 PM
