FS:: XM Satellite Radio Kit
Old Sep 26, 2015 | 06:18 PM
pglgp1292's Avatar
pglgp1292
Category: Navigation & Audio
Price: $100
Location (Region): NorthWest
Removed this from my 2006 GP. Unsure if this was installed by Mini dealer, or previous owner. Parts are in very good condition.
Kit includes:
Attached Thumbnails XM Satellite Radio Kit-20150923_131738.jpg   XM Satellite Radio Kit-20150923_131738-1-.jpg   XM Satellite Radio Kit-20151004_214700.jpg
Old Sep 27, 2015 | 05:15 AM
crashd22098's Avatar
crashd22098
Questions....
Will this work with a Harmon Kardon system? (OEM on 04' Cooper S)
Where was this located in the vehicle?
Antenna location?
I'm assuming that all cables are included?
Old Sep 27, 2015 | 11:18 AM
pglgp1292's Avatar
pglgp1292
Smile
The Blitzsafe is the part that connects to your factory wiring, and Blitzsafe don't state anything about the OEM radio/head unit compatibility. They simply state that this unit is compatible with 2001 - 2006 Mini Cooper S. My assumption is that it will probably work! give them a call to confirm (https://www.blitzsafe.com/catalog/contact-us.html)
Both the XM and Blitzsafe boxes were located behind the rear passenger side wheel well access panel. They were attached to the sheet metal with velcro tape. There is factory wiring that the Blitzsafe plugs into. You should find two unconnected wires is there, reach down towards the front of the car a bit and pull them gently out towards you.
The Antenna mounts behind the factory roof antenna. It's magnetic. The cable is routed through the rear hatch loom grommet and then just inside the roof liner (pull out the rubber seal) to the C pillar. Once behind the C pillar the cable is a straight shot to the rear wheel well area access panel. Very quick, easy and tidy. Plus easy to reverse if you need to remove it, as I did!
I hope this helps. PM me if you'd like to discuss further.
Old Sep 27, 2015 | 12:14 PM
gnhovis's Avatar
gnhovis
Reverse
Originally Posted by crashd22098
Questions....
Great system, had one for years. Yes, works with both standard and HK radio (same head unit anyway.) Fit is tight with the HK. Had an old blog post about installing it that might help: http://www.specr53.com/blog/2007/05/...sxm-radio-diy/
Good luck with sale.
Old Sep 27, 2015 | 12:41 PM
pglgp1292's Avatar
pglgp1292
Thanks for confirming gnhovis!
Old Oct 5, 2015 | 06:47 PM
pglgp1292's Avatar
pglgp1292
Bumping this up...As I just found the Owners Manual! Plus new price.
khumpert
Nov 30, 2015 11:48 AM
Zettinger
Aug 25, 2015 04:04 PM
Shane Wendel
Aug 18, 2015 01:13 PM
clintmeister
Aug 12, 2015 11:11 AM
veevsato
Aug 5, 2015 04:42 AM
