R56 Replacing turbo
Old Sep 22, 2015 | 06:10 PM
Adam Bradbury's Avatar
Adam Bradbury
Replacing turbo
Do I need to remove the exhaust manifold to get the turbo off?
Old Sep 22, 2015 | 06:42 PM
05r50's Avatar
05r50
Yes, unless you have some special tools that can get to the backside of the exhaust manifold where the turbo attaches.
That's how I swapped mine. I took the entire manifold and turbo. I also ordered a new manifold gasket and new stud bolts and nuts since I was taking it apart. I didn't want to have to do it again and it was a small price compared to the overall cost of the project.
You also need copper anti seize on those studs and nuts etc.
Old Sep 22, 2015 | 08:33 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You don't have to as I've done it without taking off the manifold, but it's easier to take it all off as one part then take the turbo off the manifold
Old Sep 23, 2015 | 05:59 AM
Diagram for your DIY. The bolts from the turbo to manifold and turbo to DP can be a little hard to get off , hit them with PB blaster and let sit first. Of course with the engine cool or cold. Replace all the hardware you remove along with the gaskets.
http://www.realoem.com/bmw/enUS/show...diagId=11_3944
Manifold :
http://www.realoem.com/bmw/enUS/show...diagId=11_3945
DP:
http://www.realoem.com/bmw/enUS/show...diagId=18_0700
Old Sep 24, 2015 | 08:30 AM
mrice0118's Avatar
mrice0118
I was able to remove mine without taking the manifold off. I used a swivel ratchet switch from Lowes like this:
http://www.lowes.com/pd_338420-25428...wrench+ratchet
WestfaliaR
Aug 19, 2015 08:01 AM
damncajun
Aug 17, 2015 08:25 PM
rckrzy1
Aug 11, 2015 06:06 PM
Aug 11, 2015 09:01 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
