:: ECS Tuning :: Better 60-0 mph
Old Sep 14, 2015 | 12:48 PM
Brake Service Kits For Your R56 R55 R57 MINI Cooper ( NON S )
Everything you need to service your brakes in an afternoon in one simple kit from ECS Tuning.
By providing it all for you in a single click, ECS makes it easier than ever to get the quality replacement matching components you need when beginning a brake service.
Our brake service kit includes rotors, pads, sensors, and assembly grease to make your brake replacement easy. A complete matched kit assembled by our team of experts, will keep all of your brake components working in perfect harmony.
Everything in one click!
Fits:
R55 MINI Clubman (2008-2014)
R56 MINI Cooper (2007-2013)
R57 MINI Cooper Convertible (2009+)
Click HERE For more options
South Bend Clutch Kits For Your R50/R52 MINI
South Bend Clutch has been manufacturing performance and street clutches for 40+ years. This dedication to product specialization makes today's South Bend products better refined compared to larger distributors.
Two Stages & Two driving styles are accommodated for, allowing you to carefully choose the exact clutch for your needs.
From daily driven to track cars they have you covered.
So Clutch
Fits:
R50 MINI Cooper (7/2004-2006)
R52 MINI Cooper Convertible (2005-2008)
Click HERE For performance options
R55, R56, R57 MINI Cooper S Brake Service Kits
If your MINI's braking performance does not inspire confidence like it used to, it is in need of a brake system service. ECS has compiled complete Brake Service Kits that make your DIY brake service straightforward and trouble-free.
Featuring OE-quality rotors, pads, pad sensors, and hardware, we've taken the guesswork out of component selection.
Simple. Click on the appropriate kit for your braking needs and we'll ship it right to your door.
A straightforward installation and voila, world-famous Porsche braking
Trouble-Free
Fits:
R56 MINI Cooper S (2007-2013)
R55 MINI Clubman S (2008-2014)
R57 MINI Cooper Convertible S (2009+)
Click HERE For BRAKE options
R55/R56/R57 MINI Cooper JCW Brake Service Kits
Trouble-Free
Fits:
R56 MINI Cooper JCW (2009-2013)
R55 MINI Clubman JCW (2009-2014)
R57 MINI Cooper Convertible JCW (2009+)
Click HERE For BRAKE Options
WAVETRAC® Limited Slip Differentials For Your Gen 2 MINI
Most truly performance-engineered European sports cars utilize a limited-slip style differential.
While an open differential effectively accomplishes the task of allowing one wheel to spin faster than the other around corners, during power delivery, this behavior is not always desirable.
In order for the full measure of power to be distributed to both wheels of your MINI, the Wavetrac® Torque-Biasing Differential automatically improves grip in low traction conditions while putting all your power to the ground.
On Trac for Performance
Fits:
R56 MINI Cooper S/ JCW (2007-2013)
R55 MINI Clubman S/ JCW (2009-2014)
R57 MINI Cooper Convertible S/ JCW (2009+)
R58 MINI Coupe' / S / JCW (2012+)
R59 MINI Roadster / S / JCW (2012+)
Click HERE For a transmission upgrade
Forge Performance For Your R60 / R61 MINI
Ready to blow off a little steam? Get Forge under your hood.
Stock diverter valves just can't handle performance upgrades. Add a little boost and they get all weak in the knees and go to pieces.
Forge knows this. That's why they've engineered boost-hardy blow off and diverter valves tough enough to take the pressure without blowing their lids.
Aluminum housing. Faster Response. Works and plays well with engine management systems.
Forge Forward
Fits:
R60 MINI Countryman S/SX ( ALL4 ), JCW (2011+)
R61 MINI Paceman S/SX ( ALL4 ), JCW (2013+)
Click HERE For Forge performance parts
ECS Performance Essentials For Your R60/R61 MINI
Why settle for stock?
ECS Essentials are a special blend of drivetrain and braking upgrades designed to pick up where the factory left off.
Each is designed to fine tune or enhance the performance and appearance of your MINI; most ship free for a limited time.
Pick one as a weekend project. Call a pal and bolt one on.
Up and Up
Fits:
R60 MINI Countryman /S/ SX(ALL4)/JCW (2011+)
R61 MINI Paceman /S/SX(ALL4)/JCW (2013+)
Brake Service Kits | MINI R50/R53 Cooper 2002-3/2003
Fits:
R50 MINI Cooper (2002-3/2003)
R53 MINI Cooper S / JCW (2002-3/2003)
Click HERE For Performance Brake options
Braking Products For Your R58 R59 MINI Coope ( NON S )
Fits: ( NON S )
R58 MINI Coupe'(2012+)
R59 MINI Roadster (2012+)
[/CENTER]
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
