:: ECS Tuning :: MORE ECS Upgrades
ECS Performance Essentials For Your R58/59 MINI
Why settle for stock?
ECS Essentials are a special blend of drivetrain and braking upgrades designed to pick up where the factory left off.
Each is designed to fine tune or enhance the performance and appearance of your MINI; most ship free for a limited time.
Pick one as a weekend project. Call a pal and bolt one on.
Up and Up
Fits:
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadter' /S/JCW (2012+)
Click HERE For more options
ECS Performance Essentials For Your F56 MINI
Each ECS product is designed to fine tune or enhance the performance and appearance of your MINI; most ship free for a limited time.
Up and Up
Fits:
F56 MINI Cooper /S (2014+)
Click HERE For performance options
Depo Fog Light Set For Your R50 / R53 MINI Cooper
An area of the front of the R50/53 MINI that often receives road wear and damage is the fog lights.
When the units become cracked, hazy, or excessively scuffed, the driver can lose visibility and the front of the car can look overly worn.
Depo replacement Fog Lights mount on the lower front bumper, and are a direct replacement for your factory housings.
Both left and right fog lights are included, and also come with a bulb and socket.
Direct-fit Replacements
Fits:
R50 MINI Cooper (6/2002-2006)
R53 MINI Cooper S/ JCW (6/2002-2006)
Click HERE For lighting options
Fumoto Drain Plug Valve For Your R52 MINI Cooper
The Fumoto 14mm oil drain valve replaces your OE drain plug for fast, easy oil changes.
Includes a threaded brass extension for oil pans with recessed drain plugs. The Fumoto oil drain valve features a ball valve with tight tolerances to ensure it will not leak once lubricated. Initially, you may wish to use a pair of pliers or a glove to turn the valve, as the valve will be stiff until lubricated during the first oil change.
Push-N-Turn-N-Done!
Fits:
R52 MINI Cooper Convertible S / JCW ( 2005-2008 )
Click HERE For FUMOTO
ECS Performance Essentials R52 MINI Cooper Convertible
Up and Up
Fits:
R52 MINI Cooper Convertible /S/JCW (7/2006-2008)
Click HERE For options
ECS Performance Essentials For Your F55 MINI
Up and Up
Fits:
F55 MINI Cooper /S (2014+)
Click HERE For performance parts
ECS Performance Essentials For Your R60/R61 MINI
Up and Up
Fits:
R60 MINI Countryman /S/ SX(ALL4)/JCW (2011+)
R61 MINI Paceman /S/SX(ALL4)/JCW (2013+)
Brake Service Kits | MINI R50/R53 Cooper/S/JCW
Everything you need to service your brakes in an afternoon in one simple kit from ECS Tuning.
By providing it all for you in a single click, ECS makes it easier than ever to get the quality replacement matching components you need when beginning a brake service.
Our brake service kit includes rotors, pads, sensors, and assembly grease to make your brake replacement easy. A complete matched kit assembled by our team of experts, will keep all of your brake components working in perfect harmony.
Everything in one click!
Fits:
R50 MINI Cooper (2002-7/2006)
R53 MINI Cooper S / JCW (2002-7/2006)
Click HERE For Performance Brake options
Fits:
Brake Service Kits | MINI R50/R53 Cooper/S/JCW 7/2006+
Fits:
R50 MINI Cooper (7/2006+)
R53 MINI Cooper S / JCW (7/2006+)
Fits:
[/CENTER]
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
