R50/53 2003 R53 XEON Hedlight transfer???
Old Sep 3, 2015 | 05:02 PM
dscott90000's Avatar
dscott90000
I have a 2003 base cooper & a 2003 S cooper.
What i want to do asap.
Take my headlights from my R50 and put them in place of the 03 S coopers XEON set up that is horribly expensive.
Has any one done this? Easy clip in or will some mods be needed.
Old Sep 3, 2015 | 05:08 PM
Spencer Roper's Avatar
Spencer Roper
http://www.motoringunderground.com/f...ad.php?t=13357
Here's a link to some info on PnP ones
Old Sep 3, 2015 | 05:14 PM
ZippyNH's Avatar
ZippyNH
Should transfer OK...
But it MAY need programming to prevent the xenons from strobing...
The halogen lights are run at slightly lower voltage on a canbuss car...to lengthen the bulbs life..
Aftermarket units avoid the issue with a huge capictor....oems USUALLY had to be coded...
Old Sep 3, 2015 | 08:46 PM
dscott90000
Im taking out the XEON lights and taking some stock r50 lights off my 03.
Old Sep 3, 2015 | 10:03 PM
Spencer Roper
Okay.....
We both said you can do that....
But you need to look into figuring out voltages upon changeover.
Old Sep 4, 2015 | 06:40 AM
batrugger's Avatar
batrugger
I went from stock halogen to pre-facelift Xenons to 05-06 projector HIDS. No modifications or programming done and they've all worked great.
Old Sep 5, 2015 | 09:11 PM
Spencer Roper
He wants to go reverse
Which I read might cause voltage issues in pre facelift halogen lights due to excessive voltage...
Have you heard of this as well in your experience with MINI?
Old Sep 9, 2015 | 05:47 AM
Manny_cooper's Avatar
Manny_cooper
I'm interested in the outcome. Why don't you swap 'em and tell us what happens. I'm selling my old Mini with xenons, and hoping I could swap them halogens in the new one with the xenons on my old one.
Old Sep 9, 2015 | 07:55 AM
Spencer Roper
You can do that....some require reprogramming the voltage.
The inverse is questionable because of the excessive voltage
sevin
May 2, 2026 06:11 AM
cawwwtun
May 3, 2016 08:03 AM
bobbiemartin
Jan 20, 2016 05:28 PM
robbiedowns22
Aug 25, 2015 12:20 PM
skippermini
Aug 12, 2015 10:05 PM
