Help! Noises!
Old Aug 31, 2015 | 04:08 PM
hooverr77's Avatar
hooverr77
Help! Noises!
I can here a ting while idling and also when I turn it off there sounds like a huge vacuum leak...I hope.https://drive.google.com/file/d/0B20...p=docslist_api
Old Sep 9, 2015 | 04:41 PM
Systemlord's Avatar
Systemlord
If that was a vacuum leak your engine wouldn't idle at all, it would stall. Even if you pull the dipstick out it would idle rough, anymore than that and it would stall. It's your valve cover relief valve venting, and what's with all the water all over your engine including your coils, MAP sensor and every clevis visible in your video?
That water didn't get there without help, the hose can be clearly seen in your video after almost stepping on it. You really did hose off your engine in an attempt to clean it!
Old Sep 10, 2015 | 01:02 PM
Bet you pour water to see where the leak was or used something on it to test for a leak?
Old Sep 10, 2015 | 04:22 PM
Systemlord's Avatar
Systemlord
I could have told him what it was without resorting to hosing off the engine, you're asking for trouble when you do something like that. He is lucky he didn't fry his alternator taking his ECU along with it!
Old Sep 10, 2015 | 05:56 PM
hooverr77's Avatar
hooverr77
Your right. I wasno thinking to clear lol. But thank you for all the help so far!
Old Sep 11, 2015 | 05:01 AM
Yea, just watch water around the engine in electrical in the future.
Old Sep 11, 2015 | 10:51 AM
Systemlord's Avatar
Systemlord
At least you got away with it and didn't cause any damage, if I were you I would try to clean up all the formation of hard water deposits from everywhere in your engine bay because I saw rusty colors in your video below the valve cover near the intake manifold.
scfiveo
Sep 27, 2019 02:27 PM
unxpectederror
Oct 22, 2015 12:16 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Miniwaukee
Sep 29, 2015 09:22 AM
