R56 Turn signal out but bulb verified ok - ideas?
Old Jul 30, 2015 | 09:12 PM
thebordella's Avatar
thebordella
Hi,
I just brought my 2010 Mini R56 to a mechanic to replace a worn drive belt. On the drive home, noticed the front passenger turn signal "fast clicking" - checked outside, no light. (Side turn signal working fine.)
The timing seemed odd since it worked fine before the shop touched it, but I thought maybe it was a blown bulb. Rather than schlep back to the shop, figured I'd replace the bulb myself. Installed new bulb. Still no signal light.
Swapped bulbs between front turn signals. New bulb works fine in driver's side. Still no passenger side signal. So, it's not a blown bulb.
Obviously I can take it back to the mechanic and tell him to fix whatever he broke. But it's a hassle that will take a bunch of time. I'm wondering if there is anything else simple I can try that might fix this myself?
I have trouble seeing the wiring in there clearly (can't take wheel off) but maybe there is a wiring connector for the signal light? Could the connection be loose? Not sure how easy it is to disconnect and reconnect with just my hand groping around up in there. Any other obvious possibilities? Just figured I'd try any low hanging fruit before sinking a couple of hours into going back to this place.
Thanks for any ideas!
Old Jul 31, 2015 | 06:16 AM
richardsperry's Avatar
richardsperry
If the old bulb works in the drivers side, you need to take it back to the mechanic. He probably unplugged it (broke a wire, killed it) when he was doing the belt.
Old Aug 16, 2015 | 04:05 PM
thebordella
Just to close this topic, the described problem was just a loose wiring plug for the signal lamp. Probably could have fixed it myself if I could have groped around up in there better, but the mechanic fixed it in 3 seconds.
Dec 23, 2015 10:36 AM
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
missinmyjeep
Aug 22, 2015 07:13 PM
kpl
Aug 11, 2015 04:52 AM
nismo4life
Aug 5, 2015 08:31 AM
