Suspension Recommendation for performance alignment in Baltimore area?
Old Aug 4, 2004 | 01:42 PM
MartyR's Avatar
MartyR
Once I install my RDR rear lower control arms, I'd like to have a shop do the camber out back. Any recommendations from you Marylanders/NoVAers?
Thanks...
Marty
Old Aug 4, 2004 | 07:12 PM
kurvhugr's Avatar
kurvhugr
The only one I've used isn't exactly Baltimore area. Curry's (http://www.currysauto.com/index.asp) is VERY good, but their three locations are all on the west side of DC.
Old Aug 5, 2004 | 06:01 AM
MartyR's Avatar
MartyR
Perfect. A friend from the BMW arena also advised me to see them. Not a problem as I have to drive in to work in Bethesda (NIH) once or twice a week... Thanks for the heads-up!
Marty
PS you ever check out ye olde wheel and welding shop?
Old Aug 5, 2004 | 06:32 AM
kurvhugr's Avatar
kurvhugr
Not yet. I got busy again and had to put it off, but I plan to call/visit soon.
By the way, when (if) you go to Curry's for your alignment, be sure to tell them you want before and after readings. That way you'll get a sense for the alignment from the factory (it varies) so you'll have a better idea of just how much you're changing things from what you're used to.
Old Aug 12, 2004 | 11:25 AM
MartyR's Avatar
MartyR
Anyone needing this sort of thing done around the Baltimore area should check out Roche's Front End and Frame north of the city on Falls Road. They set my camber and did a front end alignment for $80. Highly skilled guys - ask for Gregg!!!
Marty
sevin
May 2, 2026 06:11 AM
thebordella
Aug 31, 2015 01:37 PM
polotska
Aug 23, 2015 09:10 AM
AZN Optics
Aug 16, 2015 11:52 PM
minipopkart
Aug 13, 2015 05:22 AM
