R56 2013 Mini S R56 tires...
Old Jul 9, 2015 | 06:29 AM
dfwallace48's Avatar
dfwallace48
Have a 2013 used/ 1 owner (@ 15,000 miles) Mini 'S' hardtop with original run-flats...
Knew the car rode 'hard', but was worse than expected... Checked tire pressure 2 days ago/ were at 38-40 psi !!! Holy back-breaker, Batman!! I will reduce to @ 33 psi and rotate front to back.
This Winter or following Spring I am considering the Continental 'Extreme Contact DWS 06' tires with size at 205/45ZR/17. My buddy really likes them on his Audi TT. Is that the max width size I can get on same rims?
I currently have 195/55/16 Conti 'Pro Contact SSR'.
Old Jul 9, 2015 | 08:05 AM
rckrzy1's Avatar
rckrzy1
205/50/16 , a tad less diameter but there are many tires avail in that size, you won't find many if any 215/50/16
And if you plan to drive 100mph you are supposed to have like 40 psi , that's what my door sticker says.
But I run 35psi
Old Jul 9, 2015 | 08:36 AM
mbwicz's Avatar
mbwicz
I'm pretty happy with my Michelin Pilot Super Sports, but have read good things about the conti's.
Have fun,
Mike
Old Jul 10, 2015 | 09:19 AM
ljmattox's Avatar
ljmattox
I have those exact tires, love them. About 7k miles on this set, so far. *Much* smoother riding, and more than enough grip for the street driving I do.
Others have mounted 215/45s, sometimes they are cheaper and with more variety.
Old Jul 13, 2015 | 05:25 PM
dfwallace48
Got the run-flats psi to @ 33, rather than 40-45 !!! Much softer ride, though still of course firm...
Old Jul 15, 2015 | 03:03 PM
cWade's Avatar
cWade
I would not get Continental run flats, mine are pretty useless in the rain.
Anyone having wear issues with the pressure down to 33?
I'm running 38 now and it's improved the ride over 40+ when I bought it.
Old Jul 15, 2015 | 04:20 PM
a2oc's Avatar
a2oc
I run my R94 Dunlop SP01 runflat @33-34 psi (33 is factory recommendation) for 15k miles, no wear problem at all,but you need to rotate them regularly.
Old Aug 14, 2015 | 07:16 AM
SPYECAR's Avatar
SPYECAR
Pirelli tires
The OEM run-flats on my 2013 MCS had good dry surface traction, but were uncomfortable and noisy and were nearly worn out at 25000 miles. They were horrible in the snow. I replaced them with 205/50/16 Pirelli Cinturato P7s. Ride quality is noticeably better as is the ability to drive in snow. I don't think they have quite the dry traction as the original tires, but I'm OK with that for the type of driving I do.
TREX
Nov 2, 2019 07:31 PM
Dec 23, 2015 10:36 AM
phrza81
Oct 10, 2015 11:37 PM
marendt428
Aug 8, 2015 04:44 AM
