FS:: MILLTEK Exhaust R52 Cooper Convertible S / JCW - FREE SHIPPING *
Old May 29, 2015 | 05:41 AM
Price: $850
Private or Vendor Listing: Vendor Listing
Part fits (you may select multiples): R52
Location (Region): Midwestern
Item Condition: Brand New
MINI R52 Cooper S/ JCW Milltek Performance Exhaust Systems
Milltek's MINI offerings exude the engineering rigor and attention to detail that come from experience developing prototype exhaust designs in highly demanding circumstances for race teams throughout the world.
Every single Milltek product offering is designed and manufactured in-house in the UK. Milltek tests each system on their own dynometer through many miles of subjective analysis, fine tuning each component of each system for its specific application.
Milltek's collaboration with ECS Tuning allows unprecedented access to these exceptional performance exhaust systems.
Tested - Proven
Fits:
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE For Milltek
Attached Thumbnails MILLTEK Exhaust R52 Cooper Convertible S / JCW - FREE SHIPPING *-691916_x600.jpg
Old Feb 12, 2016 | 11:42 AM
martinb's Avatar
martinb
I'm curious....why do you only list this part as fitting an R52? Is there something different about the R52 unit compared to the R53?
Also, do you know if one of these, properly installed, will pass smog in California? (Not worried about a visual inspection.)
Finally, will it bolt right up to an existing OEM CAT-back exhaust system? My car is an '06 R52 with all possible JCW options.
Thanks!
Old Feb 12, 2016 | 11:54 AM
Hello,
There is the additional rear undercarriage support on the Convertibles, So Milltek designed a center exhaust connection for the R52 S that contains a bump or ridge ( on the rear muffler, otherwise the R53 exhaust would hit and not cure around it. So it will fit right.
Yes , it will bolt right up. Make sure you soak the old manifold bolts before you take the old system out , they tend to rust like crazy and seize, and make sure the flange is clean to mate the Milltek exhaust.
Old Feb 12, 2016 | 12:39 PM
Unbreakable Lump's Avatar
Unbreakable Lump
Hi ESCT,
Can you post a picture of the face of the flange with a scale? I'd like to know the width and height of the port openings in the flange. Looking to port a head and trying to find a header with Cat that will work with what I want to do. Also, can you provide the ID of the primary runners?
Thanks,
UL
Old Feb 12, 2016 | 12:42 PM
Hello,
I can get the specs. Don't have a scale drawing. I would have to get the specs from Milltek. Can do that. Then you will know what you can shave off. Hold tight.
flredmini
Apr 5, 2016 06:21 AM
papawhiskey
Aug 10, 2015 09:31 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
