Drivetrain DDM Scoop duct problems
Old May 27, 2015 | 08:17 AM
SkyRideTravis's Avatar
SkyRideTravis
About a year ago, I put a DDM cold air race intake on my car. I've only had one issue with it. After a few months, two of the screws holding the scoop duct to the bonnet failed, so any time I'd open it up, the thing would hang down.
I emailed DDM, and they sent me some spare screws out right away. Great service on their end
Unfortunately, it happened again. I was hoping someone has had this issue and found a better solution than replacing the screws with the same piece of hardware that seems to be prone to failure. Anyone have some suggestions? For the time being I'm just running the car with the duct, just the airbox open to the engine bay.
Thanks!
Old May 27, 2015 | 08:58 PM
Baconism's Avatar
Baconism
What type screws?
Old May 28, 2015 | 04:02 AM
damncajun's Avatar
damncajun
Loctite?
Old May 28, 2015 | 11:27 AM
SkyRideTravis
I've attached a photo of the screw and the expandable rivet piece it goes in. Both parts are plastic. These are the type that came with the intake, and also identical to the replacements DDM sent me a while back. The screw heads end up shearing off.
These are different than what they show on their website for the expandable rivets. http://www.ddmworks.com/Expandable-R...ini_p_158.html I'm almost wondering if that is what they used to provide, but the ones I have are a cheaper "equivalent" part that fails after less than a year.
Old May 28, 2015 | 01:08 PM
Baconism's Avatar
Baconism
I know how to fix it but how to explain it is hard. Google push on speed nut. then can use normal screw with threads. metal wont dry out and crack.
I will be doing same thing once I get min one.
marendt428
Feb 25, 2016 07:13 AM
Ovrclck
Aug 27, 2015 07:58 PM
Aug 27, 2015 03:18 PM
O4mcs
Aug 10, 2015 10:22 PM
