:: ECS Tuning :: Depo Lighting | R60 Wheels Spacers | R56-R59 Milltek "Cooper"
Old May 26, 2015 | 08:45 AM
MINI R58 R59 Vaico Parking Brake Cable Kits
Having proper use of your emergency brake in your MINI is a must.
Over time, brake cables can develop rust inside the plastic boot rubber, making the cable susceptible to corrosion and eventually seizure.
If your emergency brake seems to stick and lock your rear brake, or if the parking brake has failed completely, a Vaico replacement for both sides is available from ECS tuning.
Parked Assurance
Fits:
R58 MINI Coupe' / S / JCW (2012+)
R59 MINI Roadster / S / JCW (2012+)
Click HERE for parking brake cables
MINI Countryman ECS Tuning Wheel Spacer Kits
ECS Tuning lets you tweak your stance - or swagger - down the road with 5mm to 20mm wheel offsets.
Engineered and tested in-house to fit your MINI perfectly, choose from our huge inventory of hub-centric spacers in thicknesses sure to match your car, your wheels, and your shopping budget.
All ECS MINI spacers are aluminum, and are black anodized for corrosion protection.
Kits come with correct-length black lug bolts for a complete package.
Spaced Out
Fits:
R60 MINI Countryman / S / SX(ALL4) / JCW (2011+)
Click HERE For ECS Wheel Spacer Kits
MINI R56/R57/R58/R59 Milltek Performance Exhaust System
Milltek's MINI offerings exude the engineering rigor and attention to detail that come from experience developing prototype exhaust designs in highly demanding circumstances for race teams throughout the world.
Every single Milltek product offering is designed and manufactured in-house in the UK. Milltek tests each system on their own dynamometer through many miles of subjective analysis, fine tuning each component of each system for its specific application.
ECS Tuning - Largest Milltek Stocking Distributor To The Americas.
Tested - Proven
Fits: ( NON S )
R56 MINI Cooper (2007-2013)
R57 MINI Cooper Convertible (2009+)
R58 MINI Coupe'(2012+)
R59 MINI Roadster (2012+)
Click HERE For Milltek Cooper
MINI F56 NM Engineering Cold Air Intake
NM Engineering's primary goal is to improve the driver's motoring experience without changing the essence of what makes MINI a MINI.
The NM Hi-Flow Induction Kit comes in three colors, all increasing air flow to your engine for better throttle response and power. NM also offers an array of beautiful satin black, gunmetal, and satin gunmetal wheels.
Authentic NM
Fits:
F56 MINI Cooper (2014+)
F56 MINI Cooper S (2014+)
Click HERE For NM Engineering
MINI R52 R53 Automatic Transmission Filter Kit
The MINI Steptronic transmission is highly sensitive to poorly filtered or low fluid levels.
Symptoms of a transmission in need of service are lurching during acceleration and occasional gear slipping.
The ECS Assembled MINI Steptronic Automatic Transmission Service kit are an excellent way to take care of your advanced automatic transmission in one servicing.
The kit includes the transmission filter, pan gasket with gasket dowel pins (washers).
A Critical Component!
Fits:
R52 MINI Cooper Convertible S/ JCW (2005-2008)
R53 MINI Cooper S / JCW (2002-2006)
*Automatic Transmission*
Click HERE For Auto trans kit
R50 MINI Cooper Hood & Hatch Strut Kit
Don't wait to get mugged by your rear hatch or hatch glass. Replace weak struts as a set, and keep your rear hatch out of your hair when you load cargo and groceries.
Gas-filled lift struts leak pressure over time and weaken. Older struts that work in warm weather, may let the hatch or glass glass drop unexpectedly in cold weather, especially when they're carrying the added weight of snow and ice.
Now you can prevent this annoying and potentially dangerous failure with a complete strut replacement kit that includes two pairs of struts and sealing baffles.
Keep It Up!
Fits:
R50 MINI Cooper (2002-2006)
Click HERE For Hood/ hatch kit
MINI R52 Depo Fog Lights
An area of the front of the R52 MINI that often receives road wear and damage is the fog lights.
When the units become cracked, hazy, or excessively scuffed, the driver can lose visibility and the front of the car can look overly worn.
Depo replacement Fog Lights mount on the lower front bumper, and are a direct replacement for your factory housings.
Both left and right fog lights are included, and also come with a bulb and socket.
Direct-fit Replacements
Fits:
R52 MINI Cooper Convertible / S/ JCW (2005-2008)
Click HERE For Depo R52
MINI R56 Depo LED Tail Light Sets
Add eye-catching LED lighting from DEPO to your MINI with clear or smoked tail lights with LED brake lights.
These show-stopping tail light upgrades are complete LED units that plug and play with your stock wiring harnesses without causing any "bulb out" warnings.
Utilizing a smart, simple design, these tail lights look like they could have come on your MINI from the factory, and are ECE and SAE compliant.
Using bright LED lights in place of the standard brake light bulbs, the lights thoroughly update the look of your MINI R56.
PLUG & PLAY!!
Fits:
R56 MINI Cooper /S/JCW (2007-2010)
Click HERE For Depo
MINI R57 Depo LED Tail Light Sets
Using bright LED lights in place of the standard brake light bulbs, the lights thoroughly update the look of your MINI R57.
PLUG & PLAY!!
Fits:
R57 MINI Cooper Convertible /S/JCW (2009-2010)
Click HERE For Depo
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
