15in donut spare and 16in wheels compatible??
Old May 23, 2015 | 12:43 PM
cptplt's Avatar
cptplt
I had a 2011 convertible with 16 in wheels (195/55-16) and I had an extra set of winter rims/tires same size and we just got a 2012 hardtop with the 15in (175-65-15 wheels) and a donut spare.
If I put the 16 inchers on the 2012, is the donut spare (presumably designed for the 15in) ok to use on the car with 16 in wheels at the other 3 corners or should I put my can of Slime in the 2012? The tires are only 0.4in difference diameter between the 175/65-15 and 195/55-16 but those donuts always seem smaller than the originals and I dont want to be even further off size.
Old May 23, 2015 | 01:12 PM
Capt_bj's Avatar
Capt_bj
short answer is yes
from MINIMANIA's listing for a MINI donut:
If you switched from run-flat tires to standard tires, here is the spare designed for your MINI. This Spare uses the MINI factory Spare Wheel and we source the same size tire as offered on the early Cooper Spare. This spare is compatible whether you have 15", 16", or 17" tires - they all have the same approximate overall diameter. Fits R50/52/53/55/56/57/58/59
pretty common for the donut to be a different size from the 'real' wheels. Hence the warnings about speed etc . . .
{there are a lot of notes about fitment in the part description . . . esp JCW brakes}
http://new.minimania.com/part/NMW761...ver-15in-4-lug
Old May 24, 2015 | 10:09 AM
cptplt's Avatar
cptplt
Thx Capt BJ
Didnt get much use on those winter tires on the convertible so putting them on the hardtop will save some $$.
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
kazyn
Oct 25, 2019 02:34 PM
TJANK
Aug 24, 2015 06:11 PM
AdrenaliNate
Aug 24, 2015 12:37 PM
blackie
Aug 23, 2015 08:44 PM
