R56 2012 Engine Malfunction?
Old May 13, 2015 | 05:43 PM
Sassenach's Avatar
Sassenach
Purchased a 2012 Mini JCW about a month ago. Has 42k miles so still under Mini warranty. Loving it so far but.... Two days ago it had trouble getting any rpm up on a cold start, after a few mins it seemed to warm up enough to function. No codes.
Fast forward to today. My wife calls from work stating it has a message on the display saying "Engine Malfunction, Reduced power" I suggest i meet her at the local Mini dealer. They were about to close for the night so nobody could look at it. However when i went to move it closer to the door, no problems, no message.
Any ideas on what could be up with it? On a side not i am a little disappointed it does not have the signature Mini pop and gurgle from the tail pipe in sport mode. Wondering what can be done about that when it is in for warranty.
Old May 13, 2015 | 06:00 PM
AZdsrt's Avatar
AZdsrt
There will be a stored code, leave it with the dealer. At least you have some warranty left. On our 2012, the last time I got the reduced power alert, it was a failing VANOS solenoid. But in all honestly, without knowing the code it's anyones guess..
Old May 13, 2015 | 07:21 PM
Joeygonz's Avatar
Joeygonz
Got that at 70K on the clock. It was the VANOS solenoid and the HPFP, all done under warranty. Quick fix from the dealer.
Best of luck!
Old May 14, 2015 | 01:08 PM
Sassenach's Avatar
Sassenach
Mini dealer called a while ago. It was a faulty HPFP. They have replaced the pump free under warranty.
Explains the cold start problem i guess, thanks for the replies
Kimolaoha
Jul 5, 2023 01:04 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
FrostyFox
Oct 28, 2015 02:06 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
patpatpat
Aug 19, 2015 10:30 PM
