R56 oil leak?
Yea, think we talked about it here, If its the outer O -ring ( between the head and the Vacuum pump ) its listed above from systemlord, If its the main o-ring that is in the middle of the part two pump then you will need the pump.
https://www.northamericanmotoring.co...out-where.html
Clean up the oil and see if it comes from the seam on the head/ pump or at the pump seam.
Welcome.
