R56 R56 Antenna Base Seal Replacement
Old May 9, 2015 | 05:28 PM
adamsusa's Avatar
adamsusa
The seal surrounding my antenna base has deteriorated and is 50% gone. The antenna works fine, I'd like to avoid a $300-400 bill to replace the entire unit (w/sat radio).
Any ideas/suggestions on how to get just the seal? Seems like a new one would be almost like a rubber band - expands to place around the parameter.
Old May 9, 2015 | 05:54 PM
son-of-mini's Avatar
son-of-mini
Maybe try some silicone sealant? It works on boats.
Old May 9, 2015 | 06:15 PM
sgscomps's Avatar
sgscomps
The gasket is part of the base. It depends on your options as to what base you need. http://www.realoem.com/bmw/enUS/show...diagId=65_1678
Old May 9, 2015 | 08:37 PM
Systemlord's Avatar
Systemlord
You can forget about getting the sealing gasket, the sealing gasket is built-in to the Antenna Base, I bought mine from ECS Tuning for about $300 and now there $170.
http://www.ecstuning.com/Mini-2007-C...16A/ES2194788/
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:19 PM
